How many amps can this panel handle?
Discussion in 'Electrical Forum discussion & Blog' started by yellowdog5, May 5, 2009.
  1. yellowdog5
    yellowdog5 New Member
    May 5, 2009
    The panel pictured below is in my barn. It is fed with #2 aluminum wire. It currently has a double pole 60 amp breaker. I have been told I can add a double pole 30 amp breaker for a total of 90 amps. I just want to double check and make sure this is OK. I am aware of the issues with Zinsco panels.
    [​IMG]
    By at 2009-05-04
    [​IMG]
    By at 2009-05-04
  2. hj
    30 amp
    Where would you add it? There are no lugs for any additional breaker of any type.
  4. yellowdog5
    May 5, 2009
    I was going to switch to the narrow style of breakers, this way there is room for two.
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    That panel may not accept narrow breakers.
    Also, much as it goes against conventional wisdom, adding a 30 to that 60 DOES NOT "equal" 90.
    That is actually a "panel". It is a service (or main) disconnect. See the bonded neutral and grounding electrode conductor.
    What is it feeding? Is it a farm outbuilding?
  6. jimbo
    jimbo Plumber
    San Diego, CA
    You would have to read the label as to max amps, and measure the wire gauge of the supply, which I can't tell for sure in the pic.
    For what a thin 60 and another thin 30 Zinsco will cost you, why not just replace the panel?
  7. hj
    panel
    You can put two 100 amp two pole breakers, ( in fact you can put in as many as you can fit), in the box, but you will still be limited to whatever the capacity is on the breaker feeding it.
  8. yellowdog5
    May 5, 2009
    It is feeding a barn, and yes, it is a service disconnect, and it will accept narrow breakers. The wire is #2 aluminum.
  9. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    Since it is a service disconnect, what is feeding it? A breaker panel out on a pole? That is very common around here. If so you have more options but I would still replace the whole thing.
    If it is a direct feed from the power meter then you have to replace the panel with a unit that has a proper main breaker and then slots for your small circuits.
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Come on now. Please don't start sh*t like this. This is stupid/dangerous advice!
    Pulling the meter is NOT within the scope of DIY work, and even some electricians who are not allowed to.
  11. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    That's your opinion and I would respect it enough not to censor it and present only my own opinion.
    I'm not allowed to pull meters but I do it because A) it's not rocket science and B) it is a waste of resources (time and money) to schedule outages.
    Unpluging a meter is like unpluging a big extension cord. If you are an adult, you can weigh the risks and make your own decisions.
    You are not going to find a 30/60 quad breaker so you will have to have the meter pulled by a highly trained, qualified specialist and change the panel.
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    True, it is my own opinion. It is also the opinion of most every POCO and AHJ out there.
    It is also illegal in MOST areas, and is NOT smart for someone untrained to do and without PPE. It is even dumber to suggest to someone untrained to do it. That is like saying "Go ahead. Run across that busy expressway. You look quick and nimble. I'm sure you'll make it."
  13. jimbo
    jimbo Plumber
    San Diego, CA
    This debate has gotten a little testy, but felt I needed to add my 2 cents worth.
  14. Alectrician
    Jun 15, 2007
    This is testy? Heh heh....this isn't even close to testy.
    Hmmmm.....Is testy derived from testosterone? I never thought of it that way but, when guys like Petey and I get into it, there may be some testosterone involved.
  15. hj
    meter
    Here, you could pull the meter yourself, but then APS would subject you to a $25,000.00 fine for tampering, and possibly charge you will "stealing" electricity because they would not know WHEN you did it, or whether you were installing jumpers to bypass the meter socket. And, since they "pull" on the seals when they read the meter, they would know that you had cut it off. I once installed an additional service to a suite and back fed it from an existing panel. The power company initially thought I had tapped in ahead of the meter and was getting ready to write up the paperwork when they realized I was not "stealing" the power.
  16. yellowdog5
    May 5, 2009
    We have fiber optic meter reading. Wouldn't that be a sure catch for an illegally pulled meter? Don't worry, I wouldn't dream of it anyway.
  17. hj
    meter
    Yes, they could send the enforcement officers immediately to issue the citation.
  18. Alectrician
    Jun 15, 2007
    I just realized that the Zinsco bus will accept thin 2 pole breakers.
    This is a thin two pole 30 that would fit in your panel. The two pole thin 50 would be the same size. You can do what you want because of the Zinsco style bus.
    [​IMG]
    It's still not real safe to pull out old breakers in this style of panel. They do get stuck and often have to be coaxed out.
Similar Threads: many amps
Electrical Forum discussion & Blog Help! How Many "Safe/Approved" circuits in this 20 Space Panel? Mar 2, 2017
Electrical Forum discussion & Blog How many #6 wires in 3/4 inch rigid conduit? Jun 8, 2016
Electrical Forum discussion & Blog how many connections in baseboard heater? Oct 7, 2014
Electrical Forum discussion & Blog how many lights in a circuit as per code Oct 2, 2010
Electrical Forum discussion & Blog How many lights on a 15 amp breaker Mar 18, 2010
