How long to run well pump to keep storage tank full?
Edward Shilts
LlanoLonghorn
Llano, Tx
For the health of the well pump and the well is it better to run the pump 1 hour continuous or two ½ hr sessions during a 24 hr period in order to keep my 2500 gal storage tank full? The well is a 10 gal/min well and the well pump is a ½ hp Goulds.
Your submersible pump will either have a built-in check valve or there will be one mounted right above the pump. That is the only check valve you want. Unrestricted pipe is usually good.
I presume you have a float switch, to keep your tank from overflowing, in series with the timer. More common is to not have the timer, and set up the float switch to turn on when water has dropped some amount and shut off when full. The timer can make sense if you have hours when electricity is significantly cheaper.
Edward Shilts
LlanoLonghorn
Llano, Tx
Thanks Reach4, yes the tank fill level is controlled by a float switch and the timer only controls when the pump can run.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The difference between one or two cycles per day is not going to make much difference on the life of the pump. Just do whatever is best for the well. If the well needs time to recover cut the run time, if the well is strong enough just fill the storage tank and be done with it.
