How long does "galvanic corrosion" take?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Tina, Nov 28, 2004.
  1. Tina
    Tina New Member
    Nov 28, 2004
    I recently had a plumber replace a 40 foot corroded section of galvanized steel irrigation pipe with PVC. The pipe connects directly into the main water supply to the house, with no shut off valve in the event of a leak. Upon inspecting what he had done, I noticed he had threaded a copper section of pipe into the existing galvanized steel connector. All that appears to separate the copper from the steel is a thin layer of white tape and some paste material. I called after he left to ask about this, and he told me some story about a rubber gasket separating the pipes. I see the other end of the copper section (which is only about 3 inches long) is attached to the PVC through a gasket and connector, but the threaded end is definitely touching the galvanized steel. If I do nothing, how long will it take for the copper to destroy the steel? The steel is already corroded on the outside, but is still strong. Should I insist he replace the connection? This is a large plumbing company that "trains" an army of young men to go out and do their work. I don't think the people doing the work are licensed themselves. I don't want to be unreasonably demanding, but I don't want to deal with another leak in the main line any time soon either.
    Thank you in advance for any advice,
    Tina
  2. hj
    pipe
    As a practical matter, if the pipe already has corrosion it will probably fail from that long before galvanic action is a problem.
  4. jadnashua
    Part of the equation is the actual composition of your water - how reactive it is (the pH and other things). Hard to tell for sure.
  5. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    I'm just a novice but you noted something else that seemed odd to me: don't you need a water shut-off for the house. It's not just for leaks, you need it to turn off for repairs, faucet replacements, new water heater etc.
    Would a sacrificial anode made of magnesium connected to the galvanized pipe work? Magnesium is more likely to ionize and corrode.
Similar Threads: long does
Plumbing Forum, Professional & DIY Advice Where does the cleanout for long trap arm continuing into horizontal drain go? Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Why does the water take so long to warm up? Dec 16, 2010
Plumbing Forum, Professional & DIY Advice How long does it take a 1/2" copper pipe to freeze? Feb 10, 2008
Plumbing Forum, Professional & DIY Advice How long does it take a leak to dry out in a crawlspace? Jan 28, 2008
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
