How long do these shutoff valves last?
NavySuit
Florida
The house was built in 1971. I've ripped some of the drywall off of the wall. There aren't any leaks with the valves. The only problem is that the handles deteriorated and broke off. Since I have the drywall off, should I go ahead and replace the valves or just the handles (if possible) for now? Are these pretty easy to rebuild if they start leaking down the road?
Smooky
North Carolina
It is a lot easier to install the dry wall if you cut the valve off. So I would cut it off and replace it after the Sheetrock has been finished. There are good compression angle stops that are easy to add if there is enough pipe sticking out, so cut close to the existing valve.
FullySprinklered
Georgia
I'll take a shot at it. Looks like a sweat angle stop with a partially destroyed handle, with a compression tee attached?
Dj2
California
1971 valves are now...let's see, 45 years old. Most valves don't last that long.
Replace it. From the picture I can't tell what kind of valve it is, but replacing it with the same kind, would be the easiest.
Flapper
California
I'm sure it is a globe type valve (that uses a plunger that plugs the hole), just not sure what style, but it's probably a stop valve or the old equivalent to the modern stop valves:
Gary Swart
Yakima, WA
Most of us replace shutoff valves for sinks and toilets with 1/4". Valves for these fixtures should be either fully on or fully off, so no need ones that requires lots of turning. The come in compression and sweat connections.
