How Large a Water Cistern?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Montana Rookie, Mar 6, 2007.
  1. Montana Rookie
    Montana Rookie New Member
    Mar 6, 2007
    Montana
    First time user on your forum. I need advice please.
    I'm building a house, family of four. I have a well that produces 4.5 gallons a minute. I plan to put a 1500-gal cistern in between the well and house so I have adequate water upon demand.
    The question is: is one cistern "enough"?. Putting in two cisterns will add another $2000-$3000 more., which I'd rather spend on something else.
    I know this is an assumed risk...so if the well runs dry, then I will have to fill the cistern twice as frequently iwth just one tank. I'm OK with that.
    THANKS FOR ANY ADVICE.
    Montana Rookie
  2. Cass
    Cass Plumber
    Nov 12, 2005
    A family of 4 might use 4-600 gallons a day. Depends mostly on the length of showers and the type of washing machine you have. The 2 biggest users of water. I would suggest a front loading washer for reduced water consumption. Other than that I think 1 cistern is fine. If the well runs dry and water has to be trucked in you can always add another at that time.
  4. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    You might need to check local codes. In my area, you are required to have a certain amout of storage for fire fighting.
    Ron
  5. Rancher
    Rancher Guest
    Oh Yeah those galvanized 10,000 gallon tanks dotting the San Diego hillsides, the only problem is for the fire department to be able to use those tanks, they have to get to them before the houses burn down...
    Rancher
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I don't know if the cisterns are a requirement or not in your area, if not, the 4.5 gallons per minute would be plenty of water without a cistern if your well is large and deep enough. For instance a 6 inch well has 1.5 gallons of storage per foot of depth, added to the 4.5 per minute.
    I can't get too warm and fuzzy having 3000 gallons per home for fire fighting purposes. The fire department could use that up trying to put out a 55 gallon drum burning trash.
    bob...
  7. Montana Rookie
    Mar 6, 2007
    Montana
    Thank you all for the info
    Thank you all for your responses and info.
    I feel much better about saving the $2500 for a 2nd cistern and going with just one cistern for my well.
    This is very good forum and I appreciate learning from all of your experiences!
    Montana Rookie
Similar Threads: Large Water
Pumps and Tanks Well Forum & Blog What is the best and large size retention tank for well water that will save energy? Jun 15, 2014
Pumps and Tanks Well Forum & Blog Well started pumping large amounts of sand, now no water Sep 17, 2010
Pumps and Tanks Well Forum & Blog Pumping large amounts of well water May 31, 2007
Pumps and Tanks Well Forum & Blog Is larger pipe size a problem with a well? Mar 13, 2016
Pumps and Tanks Well Forum & Blog Pressure switch differential, CSV and large bladder tank Feb 3, 2016
