Dave Garner
20 year old kitchen drain stopped up tonight after wife dumped too much rice. Assumed it was the trap. As I was wiggling the trap off the 1.5" ABS horizontal pipe (after the trap) snapped right off at the wall board. Couldn't believe it as I had not applied any undo pressure to it. When I inspected the break I was surprised at what I saw. Wall board was damp like it had been leaking a little.
I have repaired a whole lotta plumbing problems over the years but this one is the first time I have had to ask for help. I would really like to NOT go into the pipes and start cutting and fitting if at all possible.
What I find odd is the way the ABS pipe looks at the break. Its a very clean break but I can see an obvious inner, middle, and outer part. (See the image "plumbing prob 2) The inner part looks kinda like its crystallized and I can sink a small screwdriver into it. The other pipe in that image is what the pipe looks like a few inches away where I cut it with my bandsaw.
One thought I had is... is there any method of reaming out the broken end inside the fitting such that I could insert a glue a new piece of pipe into it? Or is there an accepted method of gluing a replacement pipe of smaller diameter onto that piece?
