How important is access panels......
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Apr 19, 2010.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    For example, basement bathroom. Access to either sink, tub, etc is all tiled up and on the foundationside of the house.
    I'm in the planning stages of another bathroom regut.
    Sink, etc will all be on another foundation side of the house.
    Walls will be all tiled up as well.
    Knowing the location of where the tub will sit in relation to how the joists is laid up, it will most definitely be a tight fit where the drain meets the fernco fitting... May have to end up cutting the ceiling below and putting a access panel for future reference.
    Planning this all out so there's no surprises -- well, until I gut the thing and confirm my planning.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    If you put these against the foundation make sure you get a lot of extra tile...
    Access for us plumbers isn't a problem because we fix the plumbing and the wall is your problem...
    I'm starting to think this will be the remodel from hell...
    You seem to be hellbent on making this more difficult in every aspect...
    designer crap, walls without easy access...
    I'd rethink designing this and maybe stick to slinging bacon...
  4. chefwong
    chefwong Member
    Jun 14, 2006
    It's a 100 year old house. Rough ins are something I can't go drastically changing and each bathroom has the plumbing on the foundationside of the house...
    Just looking over the layout and I know that I will probably end up having to gut from the ceiling below in order to attaching the bathtub drain to the main drain stack.
    And I'm not focused on buying designer hardware (yes, probably on the towel holders and such where aesthics do count.) Just trying to be an informed consumer.
    The market for those designer brands is probably when you have a architect and interior designer doing all the planning, none of which I have ...
Similar Threads: important access
Plumbing Forum, Professional & DIY Advice What is important for a plumber Inspection camera? Jun 4, 2015
Plumbing Forum, Professional & DIY Advice Copper Vertical Vent Pipe Question (Hopefully Simple, But Very Important) Dec 4, 2014
Plumbing Forum, Professional & DIY Advice Push-Fit Connections and Deburring - a minor but important question Jul 2, 2014
Plumbing Forum, Professional & DIY Advice Charlotte Pipe TruFit System - important? Jul 26, 2013
Plumbing Forum, Professional & DIY Advice where is it important to wrap copper pipe? Jul 17, 2005
