How flat should a toilet bottom be?
Discussion in 'Toilet Forum discussions' started by Joerg, Mar 24, 2006.
  1. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Hello Folks,
    Got a Yorkville but it has to head back because of a wee curing crack in the water intake port. I called A/S and they said it's better to get a replacement. Ok, can happen. Anyway, since I wanted to get done with the wall I placed it for a "sanity check". This was quite a surprise.
    It's a back discharge commode and the rear bolts would not fit. I had them exactly six point zero inches on center as per spec. Only significant bending of the bolts would have made them go in. So, I measured and found that the holes in the toilet were less than 5-3/4" apart and also smaller than the usual 1/2" wide by 3/4" high. Same for the bottom bolts. Thank God I haven't drilled the tiles yet. The waste outlet was a bit high (I had leveled the floor tiles to exactly 4" as per spec). Also, the toilet rocked a lot, sideways and back. I took great care to have the tile floor perfectly flat, like usual in a bathroom.
    Questions:
    1. How much maximum wiggle should a toilet exhibit on a perfectly flat floor?
    2. Spec sheet distances for the screws: Do they mean anything these days?
    Quite frankly, for $280 plus tax (sans tank, of course, which is another $200) I had expected more. All the cheaper toilets I ever placed hardly needed any shims but that was a long time ago and not in the US.
    Regards, Joerg.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    A toilet should not move at all on a flat floor.
    The toilet bowl should match the specs. Talk to A/S about it and see what they have to say.
Similar Threads: flat should
Toilet Forum discussions Toilet Flange not Flat/Level Yesterday at 2:21 PM
Toilet Forum discussions Replacing flat seal in Kohler Cimarron Nov 20, 2010
Toilet Forum discussions Porcelain Quality Control - Bowl Bottom Not Flat Sep 26, 2010
Toilet Forum discussions Toilet completely flattens wax ring on flange Aug 20, 2007
Toilet Forum discussions waxless seal -flange top flat with floor Sep 18, 2005
