How far can a vent run Horizontal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by burdick101, Jul 31, 2006.
  1. burdick101
    burdick101 New Member
    Jul 31, 2006
    I apologize if this is a stupid question, but I'm having trouble figuring out the answer from my books and code checks, so here goes:
    How far can a vent run horizontal once it get up above your fixtures? For example in the attached picture:
    1) as far as I can tell, Distance "X" needs to be <6 feet
    2) For distance Y and Z, is there limitation before I turn up to the roof, or could I theoretically go across the house?
    A little critic on my plumbing setup would be apprciated as well! Thanks,
    FYI, I'm planning out a full basement bath and bar sink that is across the house from the main stack. I have another stack at the back of the house that I plan to run to, but I believe I need to run a new vent up the nearest wall to the new bath.... I don't think Seattle PLumbing code (UPC) allows side wall venting, which would have been easier.
    Thanks again,
    Nick
  2. prashster
    prashster New Member
    Dec 7, 2005
    In my town, there is no length limitation on Y, Z. However, both sections must be downward sloping to the drain so that condensate any errant water that finds its way into the system has a place to go. There should be no low points.
  4. burdick101
    Jul 31, 2006
    Thanks for your help. One more follow-up question. Can I change direction on during that long horizontal run (either Y or Z in the previous picture) as long as I keep that 1/4 per foot drop for condensate?
    I'm probably making more trouble for myself and ought to just run a new vent pipe, but fishing it up the interior wall is a real pain.
    Thanks,
    Nick
  5. jadnashua
    I think you'll find that once you are above the flood plane, as long as you have the slope to allow condensation or rain water from the roof to drain, it really doesn't matter where you go with it.
  6. prashster
    Dec 7, 2005
    Ditto. Bend me, shape me, any way you want me. As long as you love me, baby, it's all right!
  7. Terry
    Aug 17, 2004
    The X measurement with upc code would be from the vent to the flange,(six feet or less)
    The vent horizontal could be 1/3 the vertical.
    So if you had 24 feet of vertical, your horizontal could be 8 feet.
    If you go up a pipe size, there is no limit.
  8. burdick101
    Jul 31, 2006
    I'm sorry, now I think I just got confused. Terry, did you just nix what the others were saying? Perhaps you could point me in the direction of the code far that horizontal vent code?
    Thanks
    Nick
  9. burdick101
    Jul 31, 2006
    Never mind, just found it... UPC 904.2... But it says:
    "904.2 No more than one-third (1/3) of the total
    permitted length, per Table 7-5, of any minimum
    sized vent shall be installed in a horizontal position.
    Exception: When a minimum sized vent is
    increased one (1) pipe size for its entire length,
    the maximum length limitation does not apply."
    Am I mis-reading? This appears to say that it is allowed to be 1/3 the TOTAL length, which for a 2" vent would be 1/3 of 120 feet, or 40 feet.
  10. Terry
    Aug 17, 2004
    That's how it appears to read.
    1/3 of total allowed. That would mean that up to 40 feet of 2" could be horizontal without going up a pipe size.
    I wish I had seen that 10 years ago when I was doing a resturant in Bellevue. The inspector didn't see it that way.
    One third of the allowed lenth is much more than 1/3 of vertical.
Similar Threads: vent Horizontal
Plumbing Forum, Professional & DIY Advice UPC horizontal wet vent (please help) Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Vent running horizontally below flood level of rim of fixtures May 31, 2016
Plumbing Forum, Professional & DIY Advice Vent exit horizontally through gable? May 26, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Horizontal Wet Vent W Direction Change? May 6, 2016
Plumbing Forum, Professional & DIY Advice Dry horizontal vent below the flood level of a fixture........ Jan 9, 2016
