How easily will pex pipe melt near a soldered fitting?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rtc35, Apr 22, 2013.
  1. rtc35
    rtc35 New Member
    Feb 25, 2013
    Nova Scotia
    I can't afford a plumber and I don't have the tools to work with pex pipe, but I have done a fair bit of soldering. What are the chances I'd be able to heat this up enough to disconnect the copper corner fitting from the copper pipe, replace the little bit of copper piping in between (it froze and leaks now) and resolder it without melting the pex pipe? I can visualize this melting into a mess. pex-to-copper.jpg
    Thanks.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Get a product called Cool Gel, it will help as long as you don't lollygag with the torch. Unsweating though, can be iffy.
  4. hj
    I would not give you any odds of doing it. Where is the break?
  5. rtc35
    rtc35 New Member
    Feb 25, 2013
    Nova Scotia
    I'm not sure - I haven't coordinated with somebody else to turn the water on while I look. I just know it's the cold water pipe and the actual copper portion of the line is only about 6 inches long. I'm presuming it's not anywhere in the pex pipe.
    I'm seeing another option. The last time I inquired, no hardware store around me sold a pex crimper, but now Home Depot has one for $200. That's too steep, but they also sell this: Surlok Starter Set With Rings for $40 (Surlok tool & clamp starter set complete with 20 ½’ rings & 10 ¾ rings, great for home owner with small job. For fast and secure PEX pipe connections). That sounds more reasonable, unless somebody knows this product to be no good. $200 versus $40 is quite a difference.
  6. rtc35
    rtc35 New Member
    Feb 25, 2013
    Nova Scotia
Similar Threads: easily pipe
Plumbing Forum, Professional & DIY Advice Kohler sink, stains easily...poor materials or just dont make them like they used to? May 27, 2008
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Monday at 5:06 PM
Plumbing Forum, Professional & DIY Advice bathroom fan vent pipe insulation Monday at 1:22 PM
Plumbing Forum, Professional & DIY Advice Stuck U-Pipe slip-nut help Monday at 7:08 AM
Plumbing Forum, Professional & DIY Advice Any idea what a plumber might charge for repairing a copper pipe? Sunday at 12:59 PM
