How do you remove Moen Shower Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by saubouin, Oct 8, 2005.
  1. saubouin
    saubouin New Member
    Oct 8, 2005
    Here is the problem: When turning the knob on the shower faucet the water no longer comes on. However, if you remove the faceplate and use a screwdriver you can turn the water on and off. Do I just have a stripeed plastic knob or is the Moen cartirdge broken? Also I am having trouble removing the knob. I checked onthe MOEN web page and they say to use an allen wrench. But I don't see an allen wrench bolt anywere on the neck??Below is a link to a picture of the faucet.
    [​IMG]
    Sebastien
  2. jadnashua
    Does it have a little logo cover in the middle of the cap? It often prys off, exposing the bolt. Not really familar with that valve (I'm not a pro).
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Moen
    Is that a pull - push and right/left type.
  5. jimbo
    jimbo Plumber
    This is a standard Moen chateau. The screw in the picture holds the handle on. If you remove the screw, you can remove the handle. It is probalby stripped.
  6. Terry
    Aug 17, 2004
    [​IMG]
    Moen Chauteau
    http://www.moen.com/shared/pdf/2353pt.pdf
    If by moving the screw, the water will turn on, then you would need to replace the handle. A simple phillips screwdriver will remove the screw for the handle.
  7. Jaredsam
    Jaredsam New Member
    Oct 9, 2005
    Same faucet, same problem
    I have the exact same shower and problem. Have you found your answer yet, I am still needing help.
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Moen
    I'll go with JIMBO and say that it's got to do with the handle assembly.
    But where do you use the screwdriver to turn the faucet on?
  9. jimbo
    jimbo Plumber
    "On further review" of the films from "the booth" it seems it may be a Positemp, which would explain why it comes on when he turns the screw. In any event, the first step is to remove the screw and handle. The problem will then reveal itself.
  10. Oldwriter
    Oldwriter New Member
    Oct 10, 2005
    Naples, FL
    Change the handle!
    Well, I've worked with a lot of Moen controls, and it sounds like somebody (who shall not be named!) in your household gave the plastic knob a mighty twist! And broke off the little "stop" parts inside. That's my best guess.
    Use a Philips screwdriver, take off the offending knob - and order up a good lever knob from Moen - a metal one. You will be much happier. Of course, you may want to replace the Moen cartridge at the same time - how long has yours been in place? If several years - it's time for a new one. But be sure you have a Moen "cartridge puller" to help you out - the old one will probably be fairly well "cemented" in with water minerals! Good luck!
Similar Threads: remove Moen
Shower & Bathtub Forum & Blog What is this part and why can't I remove it? (Moen shower 1225) Mar 31, 2016
Shower & Bathtub Forum & Blog Remove Moen 3809 diverter spout Sep 6, 2013
Shower & Bathtub Forum & Blog moen single teardrop tub knob remove May 16, 2009
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
