How do you center an offcentered shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by taz1811, May 28, 2013.
  1. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    Just removed all the tile, 4 inches of cement, and the old shower liner and this is what I'm left with. Any ideas or suggestions on how to get this drain centered?
  2. jadnashua
    The only way to do this is to move the walls! or crack some concrete and move the pipes. Or, leave it where it is. With a clamping drain, you'll either be building another conventional shower, or use a conversion drain and switch to something like Kerdi. Or, if you do end up moving it, just a drain for the system you choose. While it is nice to have the drain centered, it doesn't have to be - it must means the slope on the shorter wall will end up steeper (if you do it the way most people recommend it and have a level perimeter).
  4. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    This is a shower in a basement that I demo'ed. So there is no pan, I'm assuming it's cemented into the house's foundation, and there is no slope. The drain is actually about an inch below all the concrete flooring. I was thinking about taking a circular saw with a diamond blade in an attempt to remove the foundation.
  5. jadnashua
    Concrete is not waterproof! Once you figure out where you want the drain, you really do need to put in a preslope then the waterproofing layer. If you use something like Kerdi, you do not need to add another mudbed on top of the liner, since Kerdi is the liner. You do need to choose the right drain, though, regardless of what you decide.
  6. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    Progress....
  7. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    The drill is actually a Dremel. I used it to cut off the old drain.
    What's next you ask?....Not sure honestly. Should I take the circular saw and cut something like this?
  8. Terry
    Aug 17, 2004
    I would take a sledge hammer to the floor, break out what is needed and then extend the horizonal waste line and install a new p-trap in the new location.
    I could almost do that quicker than I can type it. :)
    Well.............almost.
    You're getting there. The hole will need to be deeper.
  9. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
  10. Terry
    Aug 17, 2004
    Those are water pressure fittings. There is no way a snake will pass though those.
    Move the entire p-trap in the ground, and have only a vertical pipe down to the p-trap.
  11. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    Terry,
    Alright I took your advice and re did it. It was much more work than I expected, but it's coming together.
  12. Terry
    Aug 17, 2004
    Looking good!!!
  13. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
  14. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Post(s) removed by John Whipple
  15. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    Yes, I put new vapor plastic down.
    Thanks for the help guys!
  16. taz1811
    taz1811 DIY virgin
    May 27, 2013
    Washington DC
    pre-pitch and quick pitch
Similar Threads: center offcentered
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Replacing two handle shower valve with small centers May 16, 2015
Shower & Bathtub Forum & Blog Freestanding tub faucet centers Apr 28, 2014
Shower & Bathtub Forum & Blog Bathtub replacement - what to do if overflow not centered over drain Dec 2, 2013
Shower & Bathtub Forum & Blog Moen T4111 Faceplate Off Center Jun 27, 2013
