lloyda
Hello all,
I pulled a permit to install an new laundry room in my house, need to do a pressure test on the gas line for final, but I am having trouble figuiring out what to do at the meter.
Is the hex nut on the house side of the meter a shut off? If yes, do I
Shut off the gas at the meter, tighten the hex nut, disconnect the coupling on the house side of the meter, make sure all appliances are disconnected and lines capped, hook up the tester to 3/4 inch pipe and then pressurize to 10lbs?
Thanks for your help
Lloyd
Lloyd
