How do I replace a closet flange?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by smhowell, Aug 12, 2007.
  1. smhowell
    smhowell New Member
    Apr 2, 2005
    Oklahoma
    What is the procedure for replacing a closet flange? The waste pipe is 3" pvc cast into a slab. I need to replace an offset with a straight.
  2. hj
    flange
    Your safest way is to call a plumber because even after you remove the concrete from around it, you could still damage the pipe when trying to remove the old flange. They do not come off easily.
Similar Threads: replace closet
Plumbing Forum, Professional & DIY Advice Remove/replace/extend closet ring Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Replace ABS Closet bend tight space Sep 15, 2016
Plumbing Forum, Professional & DIY Advice Closet Flange Replacement Apr 1, 2015
Plumbing Forum, Professional & DIY Advice Closet Flange Replacement - Lead, Cast Iron and Brass Feb 7, 2012
Plumbing Forum, Professional & DIY Advice Replacement of Metal ring on closet flange and filling holes May 20, 2011
