How do I replace a cast iron flange?
Discussion in 'Toilet Forum discussions' started by dy, Jun 30, 2010.
  1. dy
    dy New Member
    May 2, 2010
    Bradenton, Florida
    How do I replace a cast iron flange? It is welded on I think. I removed the screws and it of course didnt come off. I have a new PVC one, but not sure how to get this flange off. The bolts are corroded and old and just keep spinning, so I need to replace it.
  2. hj
    You have a plumber break the old one off and install a new CAST IRON one. The PVC one will NOT WORK. But if the bolts are spinning, you need new bolts, NOT a new flange.
  4. dy
    dy New Member
    May 2, 2010
    Bradenton, Florida
    I got new bolts, and they keep spinning too. I dont think they are the right size , or do they have different sizes? they were the standard ones that come in with the wax ring.
  5. Terry
    Aug 17, 2004
    I normally use a washer and nut to secure the closet bolt to the flange.
    The hardware stores make you buy two sets, or look in the isle for more 1/4 20 nuts and washers.
    We sell our customers the bags with four nuts and washers.
  6. hj
    Normally they do not spin because they have "oval" heads which fit into a recess on the bottom of the flange, but most of us secure the bolts to the flange with a nut and washer. It makes it easier to remove the next time, because the bolt CANNOT spin.
Similar Threads: replace cast
Toilet Forum discussions Replacement toilet for older home with Cast Iron pipes Oct 11, 2015
Toilet Forum discussions Cast Iron / Lead Flange Condo - Repair / Replace Jul 22, 2015
Toilet Forum discussions Cast iron flange replacement? Not level, not bolted down Jul 10, 2015
Toilet Forum discussions Replace Cast Iron Toilet Flange or not? Apr 21, 2013
Toilet Forum discussions Broken Cast Iron Flange too Deep for insert replacement Sep 28, 2011
