how do i remove this price pfister handle?
Discussion in 'Shower & Bathtub Forum & Blog' started by d0u6, Sep 27, 2008.
  1. d0u6
    d0u6 New Member
    Sep 27, 2008
    there was a small screw that appears to have kept the handle on the stem but its gone and pretty well corroded. i tried pb blaster without luck. the cold side had the screw still in place and after removing it its just as stuck as the the hot. the spout has both price pfister stamped on it along with crane.
    im trying to remove handles so i can rebuild the stems. any suggestions?
    [​IMG]
  2. Terry
    Aug 17, 2004
    They make handle pullers for that.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  5. d0u6
    d0u6 New Member
    Sep 27, 2008
    right!
    i got so used to always using
    [​IMG]
    that i forgot all about these kind
    [​IMG]
    thanks!
  6. hj
    handle
    That does not look like any PricePfister faucet I have ever seen. More likely a Crane/Repcal. A hammer type handle puller or tapping on the back of the handle with a small hammer are about the only ways to get it off.
  7. jadnashua
    Since there's no through hole on the handle, I don't see how either of the pullers shown would work with that handle. What would work?
  8. Redwood
    Dec 15, 2007
    Service Plumber
    The handle is a slide hammer!
  9. d0u6
    d0u6 New Member
    Sep 27, 2008
    your right about it being crane. spout has crane stamped on it. im not sure why i thought i read price pfister!
  10. Cass
    Cass Plumber
    Nov 12, 2005
    Heat and a leather glove will remove it also...but not to much heat...
  11. d0u6
    d0u6 New Member
    Sep 27, 2008
    got the cold handle off with a little work but the hot side appears to be frozen. i cant get it to move even slightly.
    heat is the next step? anything else?
  12. d0u6
    d0u6 New Member
    Sep 27, 2008
    no luck with heat.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    When heating apply heat to the handle and keep the stem cool. the tap tap with a hammer.
  14. d0u6
    d0u6 New Member
    Sep 27, 2008
    finally got the bugger off. took heat hammering heat hammering, ect. took a while! eventually started to move though.
    thanks for help!
Similar Threads: remove price
Shower & Bathtub Forum & Blog Price Pfister Avante. How to remove a stem from shower? Aug 13, 2013
Shower & Bathtub Forum & Blog How do I remove shower handle cap from this Price Pfister? Mar 12, 2012
Shower & Bathtub Forum & Blog Price Pfister Shower Diverter Removel Nov 10, 2004
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
