How do I remove these shark bites?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CGhudson, Nov 20, 2008.
  1. CGhudson
    CGhudson New Member
    Nov 20, 2008
    I've got a couple shark bite caps on hot and cold water copper supply lines that I'm ready to remove and replace with valves (plumber put them on). I thought it would be a simple matter of pulling them off but they won't budge. What's up? Do I have to cut the pipe? :confused:
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. sixlashes
    sixlashes Plumber in Previous Life
    Aug 6, 2008
    Retired USAF Aircraft Maintenance Superintendent,
    Pensacola. FL
  5. CGhudson
    CGhudson New Member
    Nov 20, 2008
    Thanks
    Thanks much fellas. :D One more question -- do I really need a special shark bite release tool or will a pair of needlenose pliars do? (or anything else that allows me to place pressure on the collar)
  6. CGhudson
    CGhudson New Member
    Nov 20, 2008
    I suppose it would help if I actually read Redwood's reply in full -- again; muchas gracias!
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    plastic pipe hangers
    what works good is just a common
    plastic pipe hanger in 3/4 or 1/2
    they are called bassit clamps around here
    the kind that has two nails and it holds the
    copper pipe up against a stud....
    just slide it down the pipe and apply pressure
    and the shark bite will come off..
  8. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I can usually use my fingernails to pull the ring back.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    This guy might have a problem removing shark bites with his nails.
  10. hj
    sb
    Sharkbites have a collar that has to be pushed in, not a ring that you pull out. Anything that puts pressure on both sides of the tubing at the same time will help remove them.
Similar Threads: remove shark
Plumbing Forum, Professional & DIY Advice How to remove a Sharkbite Crimp Ring Nov 15, 2012
Plumbing Forum, Professional & DIY Advice remove a shark bite Mar 5, 2009
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
