How do I remove BLFC from Fleck 6700XTR head?
Discussion in 'Water Softener Forum, Questions and Answers' started by cgarai, Oct 14, 2012.
  1. cgarai
    cgarai Member
    May 12, 2012
    Sonoma County, California
    I am trying to find out what the actual size of the BLFC is. Do I need a special tool and if so, where do I get it?
    Thanks,
    Chris
  2. Gary Slusser
    Retired
    There should be a sticker on or close by to the brine and drain line connections that lists how many gpm slash lbs per minute. Or call the people you bought it from and ask them what's in it.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    a regular screwdriver will work. Fleck does make a special tool, but this is only really needed by the assemblers or guys whoe service them regularly. You need to remove the drain fitting from the drain/brine assembly, you will see that inside the drain port, there will be a plastic retainer with 4 slots in it. Insert a crewdriver blade into one of the slots and carefully unscrew the reateiner from the housing. Remove this part and the button will be easily removed. Remeber, number go toward the valve when ou reinstall the button. The button will have numbers on it that indicate the flow rate.
  5. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Dittohead, he was talking about the BLFC not the DLFC. The BLFC is located in the brass piece that the brine tube connects to. You would have to remocve the brass piece and inside is a white plastic holder. Use needle nose pliers to remove the plastic holder to get to the BLFC. I would not do thid because most of the time the plastic hloder is torn up trying to remove it and if you don't have a replacement, you can not put it back together. you can use a measuring cup and time it. .5 BLFC = 2 cup in 15 sec
  6. ditttohead
    Jan 9, 2012
    Ontario California
    LOL, thanks for that correction. I read that post after I played 2 back to back hockey games, and after a 20 hour day.
    You are spot on. Remove brass fitting, needle nose... the flow rate is molded into the rubber flow controller. The sticker should tell you, or you can simply put a 5 gallon bucket and calculate the flow.
  7. cgarai
    cgarai Member
    May 12, 2012
    Hi,
    Thanks, actually I miss-spoke and meant the DLFC, so Dittohead's response to miss-reading my message was just the ticket! Thank you both, as both pieces of info are useful.
    Chris
  8. ditttohead
    Jan 9, 2012
    Ontario California
    LOL, I am psychic! Here is a picture of the actual, proper tool, we modify it by jamming a Hex key into it.
Similar Threads: remove BLFC
Water Softener Forum, Questions and Answers Advise to remove a Flex control from tank and conversion from WS to Sediment Filter Sep 25, 2015
Water Softener Forum, Questions and Answers Eversoft removed and replaced by Culligan Apr 7, 2015
Water Softener Forum, Questions and Answers Water filter to remove lead, thalium, arsnic May 29, 2014
Water Softener Forum, Questions and Answers Bacteria after clorine has been removed? Jan 30, 2014
Water Softener Forum, Questions and Answers Deciding which carbon (GAC) filter to remove city Chloramine Sep 26, 2013
