How Do I Remove Accor Plastic Push-Pull Supply Valves?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Alkraut, Jun 21, 2014.
  1. Alkraut
    Alkraut New Member
    Sep 24, 2013
    Southwest Florida
    Hello,
    I am a handy guy who has done quite a bit of "amateur" plumbing and repairs.
    I am replacing the dishwasher in our 9year old home and the shut-offs are those nasty Accor plastic push-pull valves with the supply hose attached. The feeds are cpvc and I would like to replace the one for the dishwasher (and eventually all) with Sharkbite angle valves and metal braid supply lines. I do not want to score the cpvc by turning and yanking. I think I might be able to remove the Accor valve by using a rotating tubing cutter in the smooth section and then use end-cutters on the internal pieces. Does anyone have another method that you can share? Thanks for your advice.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  4. hj
    If you have that much tubing sticking out of the wall, just cut it off with a mini hacksaw or hacksaw blade.
Similar Threads: Remove Accor
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Remove/replace/extend closet ring Feb 9, 2017
