How do I make the snake move in drum trap drain?
deguza
Hello All:
I finally figured out how to remove the overflow knob and now have vertical access to the bathtub drain. (You can read elsewhere on Internet by travails on this matter.)
However, although I am able to get the snake in vertically, I cannot make it get it to move more that 2.5 feet. It hits something in the vertical PVC pipe and stops moving any further. I turned it and twisted as recommended on the packaging of the snake to no avail.
I looked up the schematics of drains on the Internet, I am suspecting that the PVC is connected to a horizontal pipe at this point. The snake is probably not able to negotiate the bend.
Any tricks in the trade would be appreciated.
Deguza
Krow
Ontario, Canada
Make sure the snake you are using is 1/4" in diametre . You are stopped at the bath tub p-trap. Anything bigger than 1/4" would be hard to push in. Even if you manage to get any snake bigger than 1/4" in , there is no guarantee it will come out in 1 piece or come out at all.
A spinning motion together with pushing on the cable should negotiate the p-trap bend
Jimbo
San Diego, CA
I assume you are using something like a hand-crank cable? Keep the nozzle of the cannister within a few inches of the opening of the overflow. Push while turning. When it goes in, feed a few more inches of cable. repeat.
Kingsotall
Plunger/TurdPuncher
Flagstaff, AZ
What's the drainage problem? Is toilet backing into tub too?
snake
The drain probably connects to a vertical pipe and the snake does not want to make the turn. No way to tell you how to do it, because it is something that is easier done than said. IT could even bet trying to go the wrong way, depending on how the piping is arranged.
deguza
Do you think I can access the piping in the crawl space? Would I be able to take apart the pipes down there?
Deguza
deguza
I checked the size of the snake, it is quarter inch in diameter. Of course, the head of the snake is larger.
Last night I spent another 15 minutes, but still no luck.
What if I were to dip the tip of the snake in grease? Would it make it easier?
Deguza
Krow
Ontario, Canada
Sometimes, spinning counterclockwise and pushing the cable may give you the oppurtunity to get it in. Hopefully, there is no clean out cap on the bottom of the trap.(there isn't supposed to be one) If the clean out cap is thee, then your best bet would be access from your crawl space.
Unlikely. All that will happen is that you will get grease or oil all over the place. I guess you won't know if you don't try
Redwood
I'm a pro and using my equipment I assure you I get through most tub traps in seconds of trying.
With no experience and a hand snake you are destined for a long miserable journey...
I would suggest calling a pro before your co workers start objecting to your aroma.
drain
One possibility, depending on how old the house is, is that you may have a drum trap, and if so NOTHING will get the snake to go where you want it to.
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
If it is a long drum trap the snake can go through it. If its the short trap it will not. When I see its the short drum traps I walk in with my Ro-Pump and Kinetic Water Ram.
deguza
How do I know if I have one of these traps? Go under the house?
Thanks,
Deguza
deguza
Thanks,
Deguza
I thought about this a bit more and checked on Internet. These traps seem to be several feet away from the location I am starting the snake at. I'm able to insert the snake only about 2 1/2 feet. I think I'm hitting something else. Probably the p-trap.
Deguza
deguza
Fortunately there is the local gym! I am taking my showers there. :) :D
Deguza
deguza
The house was built in 1950. It is located in San Jose, Santa Clara County. Do you think it might have a drum trap?
Deguza
drum trap
We were still using them in Chicago in the 60's. I have never been able to snake through ANY drum trap without removing its cover. 2 1/2' is almost too far to be hitting a "P" trap, and even if you were the snake would slide right through it.
