How do I join 2.75 cast pipe to 3 inch PVC tee?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by remache74, Sep 11, 2013.
  1. remache74
    remache74 New Member
    Sep 11, 2013
    Miami, Florida
    Hello I removed a rusted tee fitting from my sink drain and Im trying to replace it with a PVC TEE. My existing pipe is 2.75" ID and big box stores only sell 3" PVC tee? Any Ideas?
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Get no hub couplings (cast iron to PVC). Big box stores may not have a good selection, go to plumbing supply places which sell to the public.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Inside diameter doesn't mean anything here. Pipe size is measured from the outside. Cast iron can have different wall thicknesses, so you must use the actual measurement. You need a special banded coupler to go from the old cast iron to 3" PVC pipe. Then your 3" PVC tee will connect to that. By special, I mean one that will fit your cast iron on one end and 3" PVC on the other. You won't find it at a Big Box store. You need to go to a real plumbing supply house...one where pros buy their materials.
  5. remache74
    Sep 11, 2013
    Miami, Florida
    Okay I guess pvc and pipe are measured differently. My pipe is approx 3.25 OD and the pvc is 3.5 OD. So I will try to find a no hub reducer that will work for those numbers. Thanks for the help.
  6. Terry
    Aug 17, 2004
    Or you can pick up a copper by cast iron Mission coupling.
    Normally pipes are ID dimension. However the very old cast iron was sized more like copper pipe on the outside. Old cast may have an OD that is 1/8" larger then the stated size, just like copper pipes.
    [​IMG]
  7. hj
    It would be an unusual sink drain if it were connected to a 3" pipe.
  8. remache74
    Sep 11, 2013
    Miami, Florida
    The tee is 3x3x2...That is the sink drain taps off the tee fitting with approx 2 inch pipe....The tee then goes up to vent and down to drain.
  9. remache74
    Sep 11, 2013
    Miami, Florida
    Okay so I called a plumbing store and the lady who answered the phone says I can use a 3 x 3 no hub coupling. Saying that even though the coupling is .25 inch larger than my pipe side that it will compress to fit the pipe once I tighten. Does that sound kosher? Sorry for being a pain with the questions Im an aircraft mechanic thats used to having everthing close tolerance.
  10. Terry
    Aug 17, 2004
    No.
    But then she doesn't have to install it and make it work. So she doesn't like how the plumbers do it? My post above gives the right answer. I've been doing this in the field for forty years now.
  11. remache74
    Sep 11, 2013
    Miami, Florida
    Like you said copper to PVC no hub worked like a charm. It looks like my pipe was pre 1970 which was before the NPS (national pipe standard) was created. Explaining why my pipe was an odd OD. Thanks for the help.
  12. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    You might try going to Ace Hardware. They may carry Febco Fittings. They are an Indiana company that makes rubber fittings for odd sizes of pipes. They will tighten down with big hose clamps.
Similar Threads: join cast
Plumbing Forum, Professional & DIY Advice Old cast iron lead joints has slop new PVC doesn't Aug 29, 2015
Plumbing Forum, Professional & DIY Advice joining replacing cast iron with plastic Nov 8, 2013
Plumbing Forum, Professional & DIY Advice joining pvc to old cast pipe.... Mar 12, 2012
Plumbing Forum, Professional & DIY Advice Cast Iron joint question... May 19, 2009
Plumbing Forum, Professional & DIY Advice leaky cast iron joints Mar 19, 2006
