How do I handle this dishwasher drain setup?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TubeGuru, Aug 27, 2010.
  1. TubeGuru
    TubeGuru Unretired defense industry engineer
    Aug 27, 2010
    Redmond, WA
    I took the old GE dishwasher out tonight and found that there's a 5/8" copper pipe going through the base of the wall and off under the house somewhere (I'll go into the crawl space tomorrow to investigate). The old dishwasher was connected via a 16" rubber hose. Should I connect the new Kenmore with the new hose running flat to the drain, or should I loop it up the back wall 20" as the instructions suggest? The new hose is much longer.
    Here's a pic of the situation.
    Walt
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Yes it should loop up then back down. This is to prevent waste from going back into the DW in the event that your drain backs up. Let us know what you find in your crawl space, it should have trap.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are 2 ways to connect a DW drain. Some local codes require an air gap which is on top of the counter. The drain hose come from the DW to the air gap then from the air gap to the sink drain. The other method is allowed by other local codes. This method is to loop the drain hose from the DW up under the counter top then down to the sink drain. In both methods, the connection to the sink drain is via a special tailpiece that has a connection stub for the hose and the connection is ahead of the sink's P trap. If you use the loop method, you must be sure the hose is attached at the high point in the loop so that it will not kink.
  5. jimbo
    jimbo Plumber
    Couple of problems...we need to see what's down below. The drain needs connect through a trap, and through and air gap. We don't know if either of those things is happening. And the pipe seems just a little small. Not sure if it is adequate for the dw pumped drain.
  6. jadnashua
    It all depends on where that line eventually goes. If it runs around to the sink, it could connect like a 'normal' install, where the DW is next to it. As long as there's a minimum of a high loop before it hits the trap (and an air gap is required and recommended even if it isn't), getting the discharge to that point may very well work with what you have. WHen the plumbers installed mine, they used similar hose to get it to the sink area (mine is around the corner of a U-shaped kitchen from the sink). The hose should not be smaller than the diameter of the existing outlet hose of the DW.
  7. hj
    Impossible to answer your question without seeing the rest of the drain line. If it loops up at the final connection, then you do not want to loop it at the diswasher also. I assume the DW is not next to the sink.
  8. Terry
    Aug 17, 2004
    In the Redmond and Seattle area, the drain you are looking at is connected to a "Johnson Tee", invented by a Seattle plumbing inspector and used widely in the State of Washington. The 1/2" copper goes up above the counter height and then drops into a Johnson Tee, which has an air gap through the outer siding. The drain then drops into a 1-1/2" standpipe and p-trap.
    This arrangement gives you an air gap above the counter height, and a drain that is trouble free for years.
    [​IMG]
  9. TubeGuru
    Aug 27, 2010
    Redmond, WA
    That's great news! Based on Terry and HJ's answers, I can use the existing drain, and should not add a loop at the DW. The DW already has a built-in loop in the back. And yes, the DW is next to the sink.
    I went under the crawl space earlier and was baffled not to find anything at all (except spiders).
  10. TubeGuru
    Aug 27, 2010
    Redmond, WA
    I scraped the paint off of the air gap vent and didn't find any holes. So I presume I should drill a 1/4" hole in the cap?
  11. Terry
    Aug 17, 2004
    Yes, Jamie can drill the hole while he's out there.
  12. hj
    Did the Johnson drain fitting ever get IAPMO, or other, approval? Originally, they did not want to invest the funds for certification since it was a substantial amount. It looks like that center piece is designed to be "snapped out" after the drain is installed.
  13. Terry
    Aug 17, 2004
    It's a 3/4" PVC glue on cap. We just drill a hole through it.
    IAPMO?
    I don't know, more like one of those locally approved things that inspectors do. I've been installing these things since 1974, and it was being done long before that.
  14. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    >>>Dishwashers require an air gap. An air gap can be a deck mount or a Johnson tee type with required trim vent. (UPC 807.4 & 314.0 with exceptions per manufacturer)<<<
Similar Threads: handle dishwasher
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice How many plumbing fixtures can 3/4" supply handle Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
