how do I get to my foot valve?
Discussion in 'Irrigation / Sprinkler Forum' started by Mick, May 18, 2008.
  1. Mick
    Mick New Member
    May 18, 2008
    I have a problem with my foot valve. At least that is what I was told to look at. I have 1.5 hp jet pump, I removed that and am looking down a 2" pipe with a flashlight. I took a tape measure and hit water at 18'. I do not see anything to grab a hold of but their is definatley something there. The guy at the store told me I should be able to grab ahold of a smaller size pipe and pull it right out well point and foot valve attached. Do you have any answers for me??
    Thanks Mick
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Mick, wouldn't this question fit better in the Well and Pump section of the forum?
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If you took an elbow off the top of the well to remove the pump, you won't have any droppipe or a footvalve. There may be a Bremer Check Valve at the bottom, but you don't want to remove that. If there were a Bremer in the well, it should still be full of water.
    I assume you have a check valve in the pipe between the top of the well and the pump. Right?
    bob...
Similar Threads: foot valve
Irrigation / Sprinkler Forum extraction of foot valve Nov 12, 2007
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Valve Box Too Low - Should I Stack Boxes? Jan 31, 2017
Irrigation / Sprinkler Forum Valve, station question Aug 16, 2016
Irrigation / Sprinkler Forum Irrigation valve will not open Aug 13, 2016
