sc.homeowner
Have always had fine red clay sediment accumulate in toilet tanks but the water has been clear fo the most part. This past week has been much worse. Water had a red/orange tint to it. After the well serviceman pulled the pipe (220 ft.) thinking that it was leaking at a coupling, he found that the check valve was bad and said that the problem was caused by water flowing back down through the check valve after the pump shut off. Rather than replace a good pump he installed a check valve in the first joint of pipe above the pump and I had him put another 100 ft. above that. The water took a few days to clear after being disturbed and has cleared up substantially but still has a some murkiness to it. I am filtering with a 30 micron GE WH FILTER before the bladder tank and a 5 micron after the tank. I lose pressure in the house after a few weeks and have to change the 5 micron one. The 30 micron one last until I change it ( about every 6 mos.) but I'm always afraid it will clog and destroy the pump.
I was wondering if there is a low maintenance sediment filter that would clear this cloudiness?
The pump operates at a max. flow rate of 1o. gal/min. 9.8 amp. 1 hp.
I would like one that is self cleaning so that I don't have to worry about clogged filters.
