How do I dry vent this toilet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Glenn Gordon, Jun 4, 2013.
  1. Glenn Gordon
    Glenn Gordon New Member
    Jun 4, 2013
    Illinois
    Hi,
    I'm hoping to get some advice here on how to dry vent a toilet I want to re-position in the bathroom.
    The following picture is an overview of the room. The waste line is running laterally through the kitchen soffit below the floor joists. For the purpose of this discussion, I am focusing on how and where to bring in the dry vent line in to the toilet waste line.
    http://i624.photobucket.com/albums/tt329/freerangequark/plumbing/0.jpg
    The end of the tape measure in the next two pictures show where I want to move the toilet to. I can get the 90 in there connected to the downturned street 45. The downturned street 45 connects to another street 45 which connects up to a wye in the main waste line.
    http://s624.photobucket.com/user/freerangequark/media/plumbing/1.jpg.html
    http://s624.photobucket.com/user/freerangequark/media/plumbing/2.jpg.html
    Again, I'm only looking on how and where to bring the vent into the toilet waste line. It does not need to connect up to the vent you see in the pictures since that will all be changing.
    Thank you for your help,
    Glenn
  2. hj
    vent
    Given the way the main line is running, you do not have enough room to install the toilet where you want it, and a vent, without some major revision of the piping.
  4. Glenn Gordon
    Jun 4, 2013
    Illinois
    Thanks for the reply. That's what I was afraid of.
    Are either of the following options acceptable?
    1. Between the downturned street 45 and the upturned 90 to the closet flange I could place a sanitary T which is rolled up at 45 degrees for the vent. Is there a shorter piece that I could do this with?
    2. Replace the downturned street 45 with a wye, the bent run of the wye replaces the original street 45 and the straight run of the wye (facing up in this installation) becomes the vent?
    Thanks,
    Glenn
  5. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    Buy some fittings and dry fit it together and post a photo. Will be easier to visualize. A picture is worth a thousand words.
Similar Threads: vent toilet
Plumbing Forum, Professional & DIY Advice Venting - toilet then shower then vent Yesterday at 8:20 AM
Plumbing Forum, Professional & DIY Advice 1.5" Vent for Toilet and Lav? Mar 12, 2017
Plumbing Forum, Professional & DIY Advice Toilet vent in a 2x10 floor joist Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Toilet venting using wet and dry combination Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
