How do i connect washer drain to this?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by HJ_630, Apr 21, 2017.
  1. HJ_630
    HJ_630 New Member
    Apr 21, 2017
    Nashville, TN
    I bought a house and see this in the laundry room, how should i connect my washer drain to this? Do I need to thread a PVC pipe to this first and let the pipe go up so i can put washer drain on the pipe? Thanks
    [​IMG]
  2. Terry
    Aug 17, 2004
    [​IMG]
    Normally this is what you would have in the wall.
    A 2" standpipe with p-trap, vented through the roof, with a hot and cold supply and water hammer arrestors.
    That gray box on the left is the dryer venting.
    This is a second floor installation, so you see a vent from downstairs tying back in at 42" above the floor.
  4. HJ_630
    HJ_630 New Member
    Apr 21, 2017
    Nashville, TN
    The wall is already finished. The last person lived there took the washer and left this, i dont know how should i connect my washer drain to this...
  5. Terry
    Aug 17, 2004
    From a plumbing standpoint, I can't either.
    That's a threaded male adapter. If that is a drain of some sort, and you want to try that, it's going to need a female fitting that threads onto that.
    I have never seen a drain like that for a washer. Maybe for a drain pan that sits under a washer.
    If it's my home, I'm pulling the drywall off and taking a look to see what's up.
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    What Terry describes is what you should do.
    That looks like a PVC pipe with an NPT (MIP) thread. How big is the internal diameter? That will probably measure just a little larger than the nominal size.
    Does that pipe maybe go to the yard rather than the sewer system?
  7. Highlander
    Highlander New Member
    Dec 21, 2016
    Ontario
    Based on typical shoe molding size, that pipe is not even close to correct size for a washing machine drain (especially the new ones). Located that close to the floor makes me think it's for one of those plastic drain pans, as Terry mentioned above. Maybe the washer used to drain in the laundry tub, if there is one?
Similar Threads: connect washer
Plumbing Forum, Professional & DIY Advice New clothes washer / sink connection Feb 3, 2016
Plumbing Forum, Professional & DIY Advice Best Way to Connect 1/2" PEX to new Kitchenaid Dishwasher? (DIY advice) Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Connecting a countertop dishwasher to a Moen pullout kitchen faucet Apr 27, 2014
Plumbing Forum, Professional & DIY Advice How to Connect Sink, Dishwasher and Laundry Pump to One Drain Pipe? Mar 5, 2014
Plumbing Forum, Professional & DIY Advice Need to Connect a Countertop Dishwasher to a Nonconventional Faucet (Moen Renzo) Jan 15, 2014
