How difficult is it to replace the Anode rod
Discussion in 'Water Heater Forum, Tanks' started by paulsiu, Jun 19, 2009.
  1. paulsiu
    paulsiu Member
    Jun 18, 2009
    Itasca, IL
    Hi,
    After reading various article on water heaters, I have a better idea how it works. The role of the Anode rod is suppose to be sacrificial. It rust instead of the tank.
    Then it's logical to replace the rod every couple of years to extend the life of the tank. I was wondering if this is something that can be done by someone who's good with mechanical stuff but has no experience in plumbing. Most articles seemed to indicate that it is difficult because either there is no clearance or the rod gets stuck due to build up.
    Thanks.
    Paul
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    It's just bolted onto the top. 1 1/16" 6pt socket for A.O. Smith residential units.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    The consensus around here is an impact wrench is the solution.
  5. jadnashua
    It's the same concept as the anodes placed on a ship's hull...they get attacked before the hull does, and yes, they do need to be replaced if you want maximum life. The biggest hassle, other than getting the thing loose in the first place, is height. The average home may not have enough overhead room to get the thing out without breaking it (which isn't too bad if required). But, the new ones are available in a few configurations...one has segments that can bend, one is curved, and the stock one is just a straight rod. So, you need to know how much clearance you have. Also, depending on your water, they come in several compositions.
  6. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I did a high-rise project and the owners installed a building softener system without telling us so we could spec the right anode (the decision was made in the 11th hour before getting CO'd. 120 gallon water heaters in each unit and they had to pull the rod out and cut it to get it all the way out. The ended up not having enough room to put aluminum rods in. The GC made plans to eat the replacement cost of the water heaters that now no longer had any anode rods in them.
    120 gallon heaters x 64 units = :eek::eek::eek:
  7. paulsiu
    paulsiu Member
    Jun 18, 2009
    Itasca, IL
    So the problem is a matter of reach. I think around the heater, it's quite high, so it shouldn't be a problem.
    Any idea whether to use alum or magnesium? One site suggested that magnesium is best because it corrodes slower (and the site said aluminum may be bad for your health). I notice several post on this site citing that using magnesium rod result in rotten egg taste.
    Paul
  8. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Aluminum rods are used where some filter systems filter out chlorine (at least by my experience). When the chlorine is almost completely filtered bacteria begins to breed in the water heater on the magnesium anode rod. The bacteria generally isn't a health issue but will make the hot water have an egg smell. That's the only situation where I've ever had to spec aluminum rods.
  9. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Any problem as time goes on?
    These are threaded in, so maybe checking it every 3 years is a good idea?
    Just to at least keep the thing free from rusting together?
  10. jadnashua
    You can think of the rod rusting...but commonly we reserve that for the reaction of iron into ferrous oxide. The ions in the anode literally disolve and you're bathing in them. It works by being more reactive than the iron in the steel tank. Once it's gone, the water tries to attach the next most reactive thing. There may not be much of anything left of the rod except for the stub sealing it in the tank. Some people consider water the universal solvent.
  11. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I was thinking of the connection where the anode rod screws into the water heater. IE, that becoming rusted/stuck & difficult to remove. I hope that doesn't dissolve ;) :)
  12. jch
    jch Member
    Jan 3, 2006
    Victoria, British Columbia, Canada
    Magnesium is the most effective. Try one of those first.
    *If* you end up with a rotten egg smell (sulphur in your water supply), then switch to Aluminum.
    Rods are only ~ 20 bucks each -- the cheapest way to add years to your tanks life. If you read the fine print in your tank's warranty, you'll see a clause that says that the tank warranty is invalidated if you *don't* periodically check/replace the anode.
    I've pulled rods that haven't been touched in 10+ years, and they've been easy to remove. Just use a longer socket handle :) When the rod material is 50% gone, it's time to replace the anode.
    Does this help?
  13. jch
    jch Member
    Jan 3, 2006
    That's a great idea. Just put a label on the side of the tank stating when you last checked it.
    If you have super-hard water (or a water softener), that anode can disappear within 6 months due to the amount of conductive ions (dissolved salts) in the water.
  14. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Thanks
    I'm not sure how old ours is
    But I think maybe going on 4 years old
    I guess I should also flush it out again
    I meant to shut it off when we went on vacation & flush it when we got home
    But I forgot :(
  15. paulsiu
    paulsiu Member
    Jun 18, 2009
    Itasca, IL
    OK, I google what an impact wrench is and I don't have one, nor a compressor to drive it. Has anyone successfully do this without an impact wrench (which could be dangerous, too).
    1. Use a long pipe as a lever. However, I notice that it's possible to pull the whole heater off before the screw turns.
    2. Use liquid wrench on the nut, but wouldn't that end up in the water supply?
    3. Use heat on the bolt, may be to break whatever sealer they use on the bolt, which sounds dangerous around a gas heater.
    4. Use a hammer and a few strikes on the wrench handle to get it loose.
    Alternatively, may be there's a second Anode port on the heater? Would be easier wouldn't it?
  16. jch
    jch Member
    Jan 3, 2006
    Yes, I've done it (on a 10+ year old tank) with just a regular socket wrench.
    My advice would be to try a socket wrench first (to see if it'll work)--you might be pleasantly surprised.
    If the socket wrench can't loosen it, *then* you can look for other ways to coax it loose.
  17. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  18. hj
    everything you need to know
    That sounds like a Johnny Carson routine where he tells Ed McMahon, "This will teach/show/tell you EVERYTHING you need to know", and when Ed queries, "Everything", Johnny reiterates, "EVERYTHING".
  19. Redwood
    Dec 15, 2007
    Service Plumber
    Yup!
    Everything! :D
  20. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    There's a neat site called "waterheaterrescue" (insert dot com as usual).
    They make the claim that regular flushing and anode replacement can keep a WH alive for 20 years or more. They sell segmented rods - one of the few places I've found them on the web.
  21. jch
    jch Member
    Jan 3, 2006
    They're a great site. I have their book and it's really thorough.
    They also sell curved dip tubes to help minimize the buildup of sediment.
Similar Threads: difficult replace
Water Heater Forum, Tanks 20 year old natural gas HWH replacement options Tuesday at 6:48 PM
Water Heater Forum, Tanks Gas water heater replacement recommendations Dec 3, 2016
Water Heater Forum, Tanks Gas hot water heater is 14 years old - when to replace? May 9, 2016
Water Heater Forum, Tanks Time to replace or what ?? LP power vent water heater Jan 27, 2016
Water Heater Forum, Tanks Water Heater Replacement Help - Picture Attached Jan 4, 2016
