how deep can a p-trap go into bsmt floor
Discussion in 'Shower & Bathtub Forum & Blog' started by basementbathroom, Mar 25, 2009.
  1. basementbathroom
    basementbathroom New Member
    Mar 4, 2009
    shower is 2" drain and i want to vent with 2" as well, the sewer line is 11" deep in the cement floor, can i lower my trap below the sewer line then come up to the vent and slope down to the sewer from there, this is so i can fit everything under the new floor
    thanks for your help
  2. jadnashua
    From the outlet of the p-trap, you can only go down. That means that the bottom of the p-trap will be below the drain line.
  4. basementbathroom
    Mar 4, 2009
    will vent work properly
    what i want to do is go a foot to sixteen inches straight down from shower drain, hook on semi-circular curved part of trap, then travel straight up and connect to elbow outlet of trap at a height that would allow me to connect the vent so it will be under the floor at a decent height above the sewer drain line ( which is 11" under cement), from the vent i have to travel about 10' to the sewer drain
    i could put the trap even deeper if allowable, just want to confirm that vent will still work if i do so
  5. jadnashua
    You don't want to do that...the trap being that deep first means you'll have a change for accumulation of crud in the pipe that you'll smell and have to clean and, a trap that deep just won't work properly. You can run your vent up from the drain line within the allowances if you set the trap to what you have now.
Similar Threads: deep p-trap
Shower & Bathtub Forum & Blog Valve not mounted deep enough on finished wall - suggestions? Sep 7, 2014
Shower & Bathtub Forum & Blog A new rough-in valve thats deeper than the old Feb 26, 2013
Shower & Bathtub Forum & Blog 30x60 deep tub w/Left Drain 2 wall alcove tub? Apr 29, 2012
Shower & Bathtub Forum & Blog American Standard Deep Soak Drain May 30, 2011
Shower & Bathtub Forum & Blog Deepest 30" tub? May 17, 2011
