How can this happen?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bgormley, Jul 6, 2005.
  1. Bgormley
    Bgormley New Member
    Jul 2, 2005
    I own a double with tenants on each side. There is only one water meter so both are on the same system. But they each have a separate hot water heater. They both say that when the tenant on the OTHER side runs hot water while they are in the shower, their water gets cold. How can one tenant's hot water use affect the other's hot water use? I had new hot water heaters installed when I rehabbed the place 6 months ago.
  2. Terry
    Aug 17, 2004
    You will need to supply a larger cold water line before you split to the two heaters.
    You may only be sized for the use of one heater.
Similar Threads: happen
Plumbing Forum, Professional & DIY Advice Has anyone ever seen something like this happen (video)? Dec 31, 2016
Plumbing Forum, Professional & DIY Advice What happens if pump flow rate too high? Mar 28, 2016
Plumbing Forum, Professional & DIY Advice Has anyone seen this happen before?? Sep 25, 2015
Plumbing Forum, Professional & DIY Advice Without an expansion tank, is something happening to our water heater? Mar 22, 2015
Plumbing Forum, Professional & DIY Advice P-Stop Failure - What Happened? Jul 25, 2014
