How Can I Drain My Pressure Tank Faster
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SRADRULES, Jun 9, 2008.
  1. SRADRULES
    SRADRULES New Member
    Jun 9, 2008
    I Have A Well Rite Wr240r Pressure Tank. I Am Pretty Sure That It Is Water Logged. I Also Believe That The Diaphram Is Ruptured. Im Draining It But It Is Draining Very Slow. What Can I Do To Speed Things Up?
  2. Gary Slusser
    Retired
    The broken bladder can block the flow out the drain valve. If you are sure the tank is bad, drill a hole in it just above the weld that goes all around it and then another one on top or remove the air valve stem. You get water out the lower one and air in the top one. The water can be very rusty and stain whatever it gets on. I used to take the tank out, drag it to a floor drain and lay it on its side or its top, and drill 3/8" or 1/2" holes letting it drain into a sump pump hole or floor drain.
  4. hj
    tank
    Use an air compressor on the air schrader valve.
  5. Gary Slusser
    Retired
    That won't work if part of the bladder is blocking the outlet.
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    A pickaxe works faster than drilling holes...
Similar Threads: Drain Pressure
Plumbing Forum, Professional & DIY Advice Pressure test drain line? Feb 9, 2016
Plumbing Forum, Professional & DIY Advice Pressure relief water heater drain pipe Dec 21, 2015
Plumbing Forum, Professional & DIY Advice Negative Pressure in Drain, Backwater Valve, Zero Slope Nov 27, 2015
Plumbing Forum, Professional & DIY Advice Water heater Pressure Relief drain connection Sep 2, 2015
Plumbing Forum, Professional & DIY Advice Hot water pressure relife valve drain pipe Aug 16, 2015
