How can a drain pipe in a brick wall be repaired?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Onlooker, Oct 12, 2009.
  1. Onlooker
    Onlooker New Member
    Oct 12, 2009
    Boston
    I live in a 1929 brick building in which some the drain pipes (from tubs and kitchen sinks) are embedded into brick walls, two bricks thick on each side. One of these pipes has a crack in it so water floods into the basement. It needs to be repaired. It appears the only way to repair this is to gently remove the brick so that the leak can be accessed, but this is a really time consuming job. Is there any way to repair a cast iron pipe (I think it's 3") from the inside? Rerouting the drain is not an option because it would affect multiple apartments. Thanks.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I'm afraid that repairing it entails exactly what you are already doing.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    At least the pipe is not covered with concrete. I think you could drill holes through the mortar then use a jig saw with a coarse blade to remove the rest of the mortar. Even if you broke brick or two, unless they were smashed to pieces they would still be usable. And, if necessary, new bricks can be obtained that match the old ones.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Diamond blade on a 4" grinder takes the mortar right out, makes a hell of a dusty mess too.
  6. hj
    What is the significance of staying at a Holiday Inn Express last night. Unless it is like being in Cincinatti, where you stayed at the Holiday End for a couple of weeks last night?
  7. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Apparently you don't watch TV commercials ;)
    And I've only been to Cincinnati once in my life and it was a drive through.
Similar Threads: drain pipe
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Hard buildup in cast iron drain pipe Mar 18, 2017
Plumbing Forum, Professional & DIY Advice Attaching new PVC drainpipe to copper stub out Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Washer drain pipe Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
