How attach a new shower body valve
Discussion in 'Shower & Bathtub Forum & Blog' started by Msisell, May 1, 2013.
  1. Msisell
    Msisell New Member
    Apr 9, 2013
    Minnesota
    It sounds simple to do but when I got the new shower kit the valve part does not have flanges with screw holes to attach it. How do I set it in to stay securely?
  2. Msisell
    Msisell New Member
    Apr 9, 2013
    Minnesota
    I could post a picture if I knew how???
  4. penobscotman
    penobscotman Member
    Mar 18, 2013
    Buffalo NY
    I just did this with a Moen valve and, like you, was looking for flanges. However the directions show the valve supported by the supply lines, copper in my case. That has worked fine. My trouble was visualizing the spacing fore-and-aft in the stud cavity. The directions were nearly useless and designed for someone replacing the faucet rather than doing it as new work from scratch.
    What's your situation?
  5. Msisell
    Msisell New Member
    Apr 9, 2013
    Minnesota
    That's the exact situation for me... Directions useless. So far I put a stud in horizontally and was going to "zip tie" it in place. I just can't imagine it staying in place otherwise?? Thank you for your input!
  6. jadnashua
    Use some copper pipe straps on a brace screwed behind the valve to the supply lines. If your pipes go horizontally through studs, the holes will help stabilize things, but not enough.
  7. Msisell
    Msisell New Member
    Apr 9, 2013
    Minnesota
    Great! Thanks!
Similar Threads: attach shower
Shower & Bathtub Forum & Blog Shower Handle Fell Off; Can't Reattach Jun 3, 2016
Shower & Bathtub Forum & Blog Can't locate replacement shower diverter (Pic attached) Aug 11, 2013
Shower & Bathtub Forum & Blog Oddly attached water pipes in tub/shower Jan 18, 2013
Shower & Bathtub Forum & Blog Need to Identify Brand of 3 Handle Shower Faucet, pictures attached Sep 25, 2012
Shower & Bathtub Forum & Blog Change ShowerHead at Attachment Sep 5, 2012
