Houston, we have a problem. Well sunk?
brokenparts
Certified backyard mechnaic
Oregon
Going to try to pump water today... Cross your fingers for me.
Record what kind of pitless you are getting.
Get info on water depth if it is handy. There will be a mark on the old pipes at the water line. Write down other info.
Are you getting a submersible pump? Take a photo of the labels if you can.
Greenmonster123
Active Member
Sag Harbor, New York
I am no driller but have assisted my friend do some drilling. He uses a mud rotary rig. I noticed that when drilling a 4" well the bore hole is more like 8". The OPs well looked like 8" or 10". So I would suspect the bore hole for that if a mud rig was used could be as big as 14" or 18"? That is a lot of free area for the soil to fall into if it was very soft or after a major rain storm. The soil could have just fallen down around the casing taking the concrete pad with it.
brokenparts
Oregon
Got water flowing this weekend. Seems to be flowing at about 12gph which is a little bit more than it was before... go figure. Water was very murky at first but has cleaned up quite a bit after letting it flow for an hour or two. I'm thinking I've dodged a bullet on this one. I'll update more later.
brokenparts
Oregon
Back from the dead... I got everything resolved and things have been going soomthly until this weekend.
Recently my breaker for my well pump has been tripping. The previous owner had wired a sub panel for the pump with a 20amp breaker that goes to a 30 amp breaker in the main box. The 20amp breaker does not trip but the 30amp in the main panel does trip when the well pump (jet) shuts off. Seems like it does not trip when the motor starts or runs... just when it shuts off.
Any ideas? My first plan was to replace the 30amp breaker because that is the easiest to do and work backwards from there.
Is the subpanel feeding anything other than the pump?
Is the 30 amp breaker possibly a GFCI or AFCI breaker? I don't know if 2 pole 30 amp AFCI breakers exist.
In any case, having the breaker blow when the pump cuts off does seem odd. Your plan seems good.
brokenparts
Oregon
Is the 30 amp breaker possibly a GFCI or AFCI breaker? I don't know if 30 amp AFCI breakers exist.
It is very strange...
The breaker is not GFCI or AFCI, the subpanel is feeding other things BUT I shut them off to isolate the pump/20amp sub panel breaker itself.
brokenparts
Oregon
The only other thing note worthy to report is recent HEAVY rain after a long dry summer.
A 3/4 HP pump usually gets a 20 amp breaker, although the 15 amp breaker on my 3/4 has never tripped. How many HP is your pump?
You might as well get a clamp-around ammeter on order. That can be useful for this and future use. You don't need an expensive one. Some are under $30.
brokenparts
Oregon
Looks like I’m going to have to. Just threw in a new breaker same weird result.
