house wrap for unfinished space
Discussion in 'Remodel Forum & Blog' started by Tiimyboy, Jun 26, 2006.
  1. Tiimyboy
    Tiimyboy New Member
    May 22, 2006
    California
    My house was build in 1972 and has tar paper behind T111 siding. I am in the process of building out some previously uninhabited space (basement area under the garage) and have noticed that the tar paper does not extend to this area. This is not surprising as the space was previously empty. I am relunctant to insulate and sheetrock without addressing the weatherproofing issue. Do I need to rip off the T111 and house wrap or tar paper behind the new siding or can I wrap the existing T111 with something and then apply some kind of siding--- maybe cedar shingles, directly over the wrap? I admit that I am not familiar all that knowledgeable about construction but it seems to me that if I wrapped the T111 and then shingled that would adequate. No? Wouldn't the existing T111 serve as the sheathing in this case?
  2. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    I am not sure of the situation you are describing. Do you have a walk out basement?
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    You can wrap the T111 with something like Tyvek and then put on a siding of your preference. The T111 is simply the sheathing which goes on before the wrap. Look on Tyvek's website for instructions on wrapping after windows are installed.
    Jason
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Vapor Barrier Inside
    Condensation moves from the heated to the unheated side. If you are going to heat the area, you want a good vapor barrier inside the insulation.
  6. jadnashua
    House wraps typically let water vapor through, but stop liquid water and air infiltration. They are not typically a vapor barrier (even tar paper breaths a little). Somewhere in the last 6-months or so, Fine Homebuilding had an article on housewraps. After all of the engineered housewraps he evaluated, he said he preferred tar paper...fwiw.
  7. Tiimyboy
    Tiimyboy New Member
    May 22, 2006
    California
    water barrier
    The garage sticks out over a hillside but is not merely standing on on stilts, it is is held up by cripple walls. The space I am converting is the hollow under the garage. I just built a floor over the hill in the empty space. The cripple walls have T111 siding on them but no tar paper or vapor barrier. At first I thought I should take the siding off, put tar paper on the outside of the studs and then put the siding back up. But the siding is worn out so I decided to update by adding cedar shingles--- a popular look in the San Francisco bay area these days. In this case I would just use the T111 as sheathing, wrap the vapor barrier around the building as it stands and then add the shingles. Sound reasonable?
  8. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Your plan is fine as far as a weather barrier is concerned, but as Jad pointed out, vapor barriers serve one purpose and Tyvek type products serve another. If you like the T-111 and it is weather-tight, you can leave it alone and finish the interior space as you would any other space.
  9. Tiimyboy
    Tiimyboy New Member
    May 22, 2006
    California
    thanks
    Thank you all for the help. I think I need to read a bit more on the difference between vapor barriers and weather barriers. It seemed simple at first but now I don't feel completely comfortable. I'll look at the articles you suggested.
Similar Threads: house wrap
Remodel Forum & Blog Tyvek house wrap without logos defacing it? Nov 23, 2012
Remodel Forum & Blog Tyvek and other House Wrap Options May 2, 2006
Remodel Forum & Blog Window replacement plus house settling Nov 20, 2016
Remodel Forum & Blog Advice on gutting a bath in 1930's house Mar 6, 2014
Remodel Forum & Blog Rerouting sewer drain on outside of house? Jul 23, 2013
