House Water Filter
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dfisher, Dec 5, 2012.
  1. dfisher
    dfisher New Member
    Dec 5, 2012
    Virginia
    We had a plumber install a water filter after we discovered black flecks in our water. (presumably these are coming from local construction) Today we discovered water damage from a cracked valve on the filter. The plumber replaced the valve with a copper valve. I was curious if the water pressure is what cracked the valve and if anyone had seen an installation like this.
    http://imageshack.us/a/img255/7261/imagezkwd.jpg
    Thanks.
  2. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    I don't know anything about anything so I can't be of help, but these types of posts interest me, because I look at that and think there's no way that can be done right, but I'm probably wrong.
    Shark bites, zip ties, chopped up 2x4's, it all looks bush league to me, even if it somehow is right.
  4. Terry
    Aug 17, 2004
    I can't tell from the picture which fitting your are thinking about.
    Generally we don't use a male adapter into a plastic female fitting, but there are some filters that are made that way. It can split the fitting. Not always, but it can happen.
  5. dfisher
    dfisher New Member
    Dec 5, 2012
    Virginia
  6. Terry
    Aug 17, 2004
    Pressure is determined by how high the water is in the water tower.
    It has nothing to do with pipe size.
    Homes the farthest below the tower have higher pressure, homes at the top of the hill have less pressure.
    Small pipes can increase friction, which in turn can reduce the volume of water that can go though a pipe.
  7. dfisher
    dfisher New Member
    Dec 5, 2012
    Virginia
    Thanks Terry.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There is no way I would have allowed this to be plumbed with PVC. PVC is not supposed to be used for water lines inside a house. I see you have galvanized pipes elsewhere which is going to give you trouble someday, but I would have insisted on copper lines for this filter. As Terry says, pipe size has nothing to do with pressure, only flow. If you have too much pressure then you need to adjust the PRV...it appears that you have one. Get a pressure gauge and monitor the pressure.
  9. dfisher
    dfisher New Member
    Dec 5, 2012
    Virginia
    When you say it's not supposed to be used, does that mean it probably violates housing code in my state?
    Also, if I get a different plumber in to fix this, can you recommend a water filter that is more suited to be installed in this location?
    Thanks.
  10. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    The Virginia plumbing code is here:
    https://www2.iccsafe.org/states/Virginia/Plumbing/Plumbing_Frameset.html
    See Section 605.3 and 605.4. PVC is allowed for "water service pipe". As mentioned in 605.3 and in the definitions (Section 2), the water service pipe is under ground and outside of the structure (generally allowed into the stucture to the shutoff).
    For "water distribution pipe", you will see that PVC is not listed as an approved material (but CPVC is okay) in Table 605.4. The distributon piping is all piping within the house. The main issue with PVC is that its rated pressure decreases with temperature. As mentioned in 605.4, the hot water piping must be rated to 100 psi at 180F. The max service temperature for PVC is 140F, so that is why it isn't okay for hot water. It has also been mentioned on here the people have seen bulging PVC cold water pipes that were run through a hot attic.
    So, technically, PVC for your filter is against code, but practically, it doesn't matter as long as it was cold water only and not placed in a hot area (like an attic). A plumbing inspector may or may not fail this, depending how strict they were on the code.
Similar Threads: House Water
Plumbing Forum, Professional & DIY Advice Installing a whole house water filter by myself? (not a pro) Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Knocking pipe and water "spitting" in highest shower in house Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Replacing valve at waterline shutoff to house Oct 26, 2016
Plumbing Forum, Professional & DIY Advice Adding a whole house water filter.... Oct 5, 2016
