Hotwater baseboard does not heat up?
Discussion in 'HVAC Heating & Cooling' started by penguin933, Oct 5, 2008.
  1. penguin933
    penguin933 New Member
    Oct 5, 2008
    What could be a reason why a hot water baseboard does not heat up as fast as the other ones? i have 5 rooms with hotwater baseboards. 2 of them dont heat up as fast as the other 3. The baseboard that does heat up fast is in the room with the thermostat so it turns off way before the baseboard in the other 3 rooms get hot. Could there be some valve i need to turn or something?
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    distance would be one factor... the heaters closest to the hot water supply will heat up much faster than the heaters at the end of the loop.
  4. penguin933
    Oct 5, 2008
    well i really dont hear water running there that good. The fins dont seem to be getting hot ethier. Tomorrow i Will ask my landlord if there is a valve or something
  5. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    You could have an air bubble in the line serving that radiator.
  6. penguin933
    Oct 5, 2008
    well its happening in the other rooms too except for the rooms that are next to the room where the thermostat is.
  7. Southern Man
    Jun 27, 2008
    North Carolina
    The bubble would affect all the rooms in that loop.
    Is there more than one zone?
    I had a ranch house with a single zone system. It had two loops, each serving a side of the house, with a common return line. If one side got a bubble that entire side of the house would be cold.
  8. penguin933
    Oct 5, 2008
    the house is a 3 family apartment built in i think 1908. there are 3 floors. The furnaces are in the basement.
    There are 3 of them one for each floor. There are 4 hot water tanks in the basement as well one for each floor and one for the wash machine i believe. We just turned the furnaces on for the winter. The landlord likes them off in the spring + summer. The hotwater tanks are like this but this isnt a picture of my tank its like that one.
    http://www.cpsc.gov/cpscpub/prerel/prhtml08/08241A.JPG
  9. penguin933
    Oct 5, 2008
    I found this on the deed page
    Heating Type: Water
    Fuel Type: Gas
    System Type: Basic
  10. Southern Man
    Jun 27, 2008
    North Carolina
    In a furnace, flue gas acts on a heat exchanger full of air that is then circulated directly through the house. That's not what you have.
    In your building, the space heating is done by gas boilers. The hot flue gas acts on a heat exchanger filled with water. The water is then pumped to the radiators.
    The tank that you showed me is a domestic hot water tank. It heats your water that you use for washing. These systems are unrelated to the space heating systems.
    Does the boiler heating your floor have one zone or several. I'm guessing that it is one. You could, however, have two or more loops as I described for my ranch home. Each loop should have an air release valve located at its highest end, as well as a separate hand-operated valve that can be used to reduce the flow through that loop. These can also be used to diagnose and sometimes solve problems.
  11. penguin933
    Oct 5, 2008
    Hmm i have to take a look i will post back in a couple of hours as i am busy right now.
  12. penguin933
    Oct 5, 2008
    I didnt see any loops then again it was dark outside and the basement lights are dead. I will look again tomorrow. I did see a puddle of water behind the boiler though. The other boiler had water behind it too.
    The first room where the copper pipes that bring hot water into is in the kitchen. The kitchens baseboard barly gets hot.
    So i think there is a loop i will look again tomorrow when there is light. And there is only one zone in the boiler too.
    Is the puddle behind the water normal?
  13. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Bad zone valve or bad circulator.
  14. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    In your case it's easy!
    You call the landlord and say I don't have heat!:cool:
  15. Southern Man
    Jun 27, 2008
    North Carolina
    Check to see if you have manually operated valves in the lines circulating water to the radiators. There should be one for each loop.
    Water on the floor means something is leaking, which isn't uncommon, but not "normal". A lot of times the T&P valves leak. A little bit isn't going to hurt anything.
  16. penguin933
    Oct 5, 2008
    HI
    Sorry for not replying in a month, I went on vacation and was very busy the last few weeks.
    Its now in the 30s here everyday and the teens at night. A couple of rooms are very cold because the heat still works poorly.
    The landlord said its a one zone furnace and there are no loops. He said to bleed the radiators but i dont have radiators in my apartment they are baseboards.
    The baseboards in the cold rooms do get hot after 20Mins but that is when the furnace turns off. It takes about 8Mins for the rooms where the heat works very good to get very hot like that ones at my old house. (14 Year old house). So could it be distance? I am going to take another look in the basement in a few mins.
  17. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Why is your landlord not taking care of this? That's what you pay rent for isn't it?
  18. penguin933
    Oct 5, 2008
    The thing is he knows nothing about furnaces he has this guy take care of him but he is out of town until december.
  19. penguin933
    Oct 5, 2008
    I think it is a valve issue. I felt the return valves in the other 2 furnaces and they were hot and i can feel the water stream in them. My return valve is not that hot and i can feel little water going thourgh it.
  20. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The question still is.. So what? are you going to buy the parts and do the repair? Tell the f'ing landlord to call a service man or you will stop paying the rent.
  21. Redwood
    Dec 15, 2007
    Service Plumber
    Zackley!:cool:
Similar Threads: Hotwater baseboard
HVAC Heating & Cooling Aquatherm Hotwater Heat System. Nov 19, 2009
HVAC Heating & Cooling Electric Hydronic Baseboard, Or Regular Convectors? Sunday at 8:23 PM
HVAC Heating & Cooling Cast Iron Baseboard location in bathroom remodel? Mar 23, 2016
HVAC Heating & Cooling add ANOTHER baseboard to monoflo tee? Oct 24, 2015
HVAC Heating & Cooling Shortening baseboard radiator Oct 19, 2015
