hot water when it should be cold
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by drleb, Sep 27, 2004.
  1. drleb
    drleb New Member
    Sep 27, 2004
    Help! within the last 2 months several faucets in the house have had identity problems...
    The cold water faucets produce extremely hot water. This has happened in the kitchen, bathrooms and even in the shower. It does not happen all the time, but probably 60-70% of the time. Sometimes the cold water will come back after a few minutes but sometimes it just stays hot. What in the world is going on?
    Larry
  2. dwpecksr
    dwpecksr New Member
    Sep 27, 2004
    owner Dale's Plumbing Service inc
    Kansas
    You may have a mixing valve that is allowing the water to mix and cross into the cold side. You don't say if you have a boiler with a coil in it. It could be a bad stem in a single lever faucet. start by trying one faucet at a time. see if you can isolate the faucet where it starts.Do you have hot water coming into the toilet?
    Dale
  4. jimbo
    jimbo Plumber
    Do you have a retrofit recirc system installed? Do you have a termpering valve on the toilet?
  5. drleb
    drleb New Member
    Sep 27, 2004
    The kitchen faucet is a Delta single lever. I replaced all the "guts" of it and still have the problem. The bathroom faucet is a 2 lever (hot & cold each having their own handle). We have a RUUD water heater that is only a few years old. Haven't noticed any hot water into the toilets but will check.
  6. dwpecksr
    dwpecksr New Member
    Sep 27, 2004
    Kansas
    check valve
    You can try installing a check valve on the cold water inlet to the water heater. This would require an expansion tank. Maybe you already have an expansion tank? If it sounds full it is a bad tank. The wash machine valve in the washer may be your problem also.
    Dale
Similar Threads: water should
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Should I replace my water heater Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Replacing Toilet Water Valve, should I remove old ferrule and compression nut? Aug 9, 2015
Plumbing Forum, Professional & DIY Advice What type of fitting is this, and what should I replace it with (underground water line) Jun 14, 2015
Plumbing Forum, Professional & DIY Advice Should I flush my new AO Smith GCV-50 water heater every 6-12 months? May 30, 2014
