Hot (water)time in the summer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dhla, Jun 28, 2010.
  1. dhla
    dhla Member
    Mar 3, 2009
    Los Angeles
    Got a question - don't know that there's anything I can do to remediate... not sure even where to look, but thought I'd post the situation and see if anyone had any good advice.
    In the summer (in Los Angeles) when it is hot, if I run the water in the mid/late afternoon, even the cold comes out pretty warm, and the hot water comes out very hot. Don't have the problem in the fall/winter/spring, so somewhere along the way, the cold water line must be getting exposed to the sun.
    Any suggestion about how to find/how to remediate? Or just live with it??
    Thank you!
  2. worsnup
    worsnup plumbing contractor
    Jun 7, 2010
    plumbing contractor
    phoenix az
    in phoenix we live with it
  4. jadnashua
    The lines are probably run through the attic. Add more insulation, maybe a reflective barrier to lower the attic temperature and the heat load, and it may help some. Running the pipes through an interior wall in conditioned space would help, but that means tearing up a lot of wall, and then getting it where you want is tougher.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Move North! Our temps run in the high 30's winter - 70's in the summer....
  6. hj
    hot
    Usually no cure and you live with it.
  7. dhla
    dhla Member
    Mar 3, 2009
    Los Angeles
    That's what I figured - thank u!
Similar Threads: (water)time summer
Plumbing Forum, Professional & DIY Advice Heating not turned on during summer , banging and clanging from pipes Oct 29, 2014
Plumbing Forum, Professional & DIY Advice Winter - Summer Hook Up May 11, 2009
Plumbing Forum, Professional & DIY Advice Outdoor Faucet Alternatives for Summer Use Jun 9, 2008
Plumbing Forum, Professional & DIY Advice Summer Cottage Hot Water Heater Questions May 9, 2008
