hot water temp loss when I pull up the shower diverter
Discussion in 'Tankless Water Heater Forum' started by forbins, Feb 10, 2011.
  1. forbins
    forbins New Member
    Feb 10, 2011
    Marshall, NC
    hey all, new the board, please help me if you can
    i'm a jack of all trades master of none kinda guy, i've installed a Bosch Aquastar 125 in my house. We have a small house, only one bathroom. The unit seems to be working great. The kitchen sink, bathroom sink, washing machine and bathtub all get really hot. The problem is when I pull up the show diverter on the bathtub spicket. As soon as I pull it up I can visibly see the flame go down on my tankless unit and the end result is a luke warm shower. I can get it flame up and produce hot water again if I turn on the bathroom sink while the shower is running. Also don't if it's related, but if i have the hot water on in the bathroom sink on and my wife turns on the hot water in the kitchen sink there is significant pressure loss.
    i've been reading about thermostatic shower valves vs pressure balance valves.
    please help, haven't had a decent shower in a while!!!
  2. jadnashua
    All tankless use a system to detect flow, and only turn on when that flow exceeds a certain value (differs by brand and model). You may have a super saver showerhead, or you like it cool, because it sounds like you aren't getting the flow needed to keep the thing turned on. That's why, when you also turn on a sink, the increased flow triggers it to turn on. You might try a different showerhead.
    A thermostatically controlled shower valve is nice, but it can't magically generate hot water...if it isn't coming in, it can't adjust. But, if the temp varies while the shower is going on, it will try.
    Also note that many tankless systems have a flow restrictor in them, and this can mess up both pressure balanced and thermostatically controlled valves. Read the info carefully, and check with the manufacturer before investing in making a change.
  4. Henryj
    Henryj New Member
    Feb 10, 2011
    Maryland
    Water flow
    Just change the shower head for one with higher flow, water flow is not sufficient to activate flow switch in water heater.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Before you run out and buy another shower head, take off the existing head and test it with just the stub pipe to see how much flow there is. Some of the newer valve assemblies put a restriction on the shower line to ensure enough back pressure for the anti-scalding pressure balancing to work well.
    Inspect the inside of the shower head thread fitting. Some place a restrictor there that may be removed or drilled larger.
  6. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    I'll bet that tank is undersized.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I know, it's a tankless job. :p
  8. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Had that problem often with the old Price Pfister 2 handle valves. Remove the restrictor on the shower head. Or buy a new shower head and remove the restrictor before installing it.
Similar Threads: water temp
Tankless Water Heater Forum Contolling Circulator Pump by water temperature Oct 7, 2013
Tankless Water Heater Forum Noritz Water Temperature Fluctuations May 21, 2013
Tankless Water Heater Forum NORITZ Tankless Heater--water temp fluctuation Feb 13, 2008
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Rheem water heater need trouble shooting. Jan 14, 2017
