Hot Water Tank
Discussion in 'HVAC Heating & Cooling' started by seeker, Nov 11, 2007.
  1. seeker
    seeker New Member
    Jan 22, 2005
    We are building a new home (NJ) and the Gas Hot Water Tank is planned to be in the garage next to gas furnace , both on a platform adjacent to inside wall of a bedroom. I was wondering what insulation rating and enclosure with heat is recommended if any.
  2. jimbo
    jimbo Plumber
    Gas water heaters these days are pretty well insulated. If you buy the top or the line unit from any brand, it has even better insul. than the "standard" model. You can only get so good with gas, because a lot of energy goes up the flue when the burner is running, and there is significant heat loss just from convection up the flue even when it is not running.
    You can add a blanket around the tank, but are prohibited from putting any blanket on top, since it would interfere with the draft hood.
    Direct vent and power vent heaters have better efficiency numbers, but cost a lot more up front.
    You mentioned an "enclosure". If a water heater is in any kind of enclosed space, there are very specific requirements for combustion air which you must provide for.
    So, you have a few issues to look into, in advance, before you but something and commit to it.
Similar Threads: Water Tank
HVAC Heating & Cooling Hydronic air handler: tankless water heater or heat pump Aug 11, 2013
HVAC Heating & Cooling deactivate buderus hot water tank Oct 21, 2010
HVAC Heating & Cooling Possible Water in Oil Tank Nov 7, 2009
HVAC Heating & Cooling Decision Made...Going to Electric Hot Water Tank. A Few Questions. Jun 26, 2008
HVAC Heating & Cooling Water Softener - Tankless Oct 12, 2007
