hot water tank relief value leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by guateman9, Nov 12, 2008.
  1. guateman9
    guateman9 New Member
    Nov 12, 2008
    Hi all, have a older hot water tank that has worked fine for 3 years. Recently when we turn on the electricity(we keep it turned off to keep the light bill down) to take showers, when it gets hot the relief value opens up and a good stream of water comes out until we finish with our showers and turn off the electricity to the tank. Probably as the water temp goes down. Then no more water comes out of the relief value.
    I assume I need to replace the relief value? What do you think,
    Thanks and I live in Guatemala where my electricity bill runs $ 300 a month or more, so saving electricity is a priority. And if you need to know, I am from Denver originally,
    Cheers everyone,
    Scott
  2. Terry
    Aug 17, 2004
    How old is old? Longer then 3 years or something like ten years?
    If there is no other reason for the leaking PRV, other than the spring finally got old, then a simple replacent should do it. The hardware stores carry them on the shelves down there.
    Most of the plumbing parts there remind me of the US, except for how they run the pipes in the wall.
    If after replacing the PRV, it still gives you trouble, then it could be something like the thermostats, thermal expansion or high water pressure.
    I would change the PRV first.
    [​IMG]
    Guatemala
  4. guateman9
    Nov 12, 2008
    thank you
    Terry, thanks and will give it a try and let you know. If you visit here, look me up. Great place, gets alot of bad press, but actually love living here,
    Scott
Similar Threads: water tank
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Sedimentation Tank for Domestic Well Water System Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Source for water tank, thinking of settling grit before pressure tank Nov 13, 2016
Plumbing Forum, Professional & DIY Advice Running hePex on Hot Water Tank Nov 3, 2016
