hot water tank life span
Discussion in 'Water Heater Forum, Tanks' started by rburt5, Dec 22, 2009.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    About how long does a typical hot water tank last? Mine is from 1996 and I'm thinking about starting to save up for a new one. My house has very hard well water - in case that matters.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Start saving, most last from 7 to 10 years. Yours is over do.
    John
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Assuming it's a NG WH, and assuming my samples are representative of all NG WHs, the avg. replacement age is 17 yrs, +/- 3 yrs.
    Wearout age, when you get an increasing failure rate for each component, is equal to or longer than this.
    Given that it has survived this long, you have an even chance of making it to ~19 yrs.
  5. curlysir
    curlysir New Member
    Sep 21, 2009
    Texas
    It depends on your location and quality of water. In the Texas panhandle where I lived for 30 years, 10 years life was very unusal, 6 to 7 was average. Water was hard and corroded the plumbing and appliances. Where I live now in east Texas I replaced a 12 year old heater that when I examined it after removal was in good shape. I replaced it based on my previous experience which did not apply in this location. Water here is much better and plumbing has much longer life.
    From your descripition I would say yours is getting close to the life expectancy.
  6. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    It probably also depends on how hard you run it. If you have 6 people in a household, use several times the Energy Guide quantity of hotwater and crank the temp. up it will likely die much sooner than a heater running 30 F cooler and fired less frequently.
    While running a higher temp could result in less total water throughput there are at least two major negatives with regard to heater life: 1. Wall/flue temps will be higher, and corrosion rates generally increase rapidly with temperature. 2. The mineral carbonates in water generally have retrograde solubility--meaning that they precipitate more easily at higher temperatures. The is the opposite of most other solids which dissolve more readily as the solvent (water) becomes hotter.
  7. hj
    life
    They last from ONE DAY to 25 years, depending on whether it is gas or electric and how much water you use.
  8. Terry
    Aug 17, 2004
    I've installed a couple on one day'rs.
    Kind of disappointing when that happens.
  9. hj
    Heater
    The only good thing is that the manufacturer does give a slight cash payment when it happens.
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    one day
    "infant mortality" failures, due to factory defects
    http://en.wikipedia.org/wiki/Bathtub_curve
    Anybody have replacement ages for resi. NG or resi. elec. WHs that I can add to my spreadsheet? :confused:
    The reasons for failures are another issue.
Similar Threads: water tank
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks Expansion Tank, and other water heater questions.......... Jan 28, 2017
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Best Tankless Water Heater Brand? Jul 8, 2016
Water Heater Forum, Tanks Water heater tank flushing process Jun 13, 2016
