bree
- Messages
- 5
- Reaction score
- 0
- Points
- 0
I had a slab leak about a year ago. A licensed plumber rerouted the line through the ceiling. At about the same time, a different, experienced plumber installed a new single-arm kitchen faucet. (We had had a new angle stop put in about 6 months prior.) When you turn the faucet handle to full hot, after a minute or two the hot water would suddenly shut off completely with a thud-like sound. At first you could wait a couple of minutes, turn the cold water on, and gradually turn it up to full hot again and it would run for a short while before stopping.
The faucet mfr sent us a new cartridge; same problem. A second new cartridge; same problem. A whole new faucet; same problem. Another new cartridge; and then another. Same problem!
The plumber took the first faucet and the cartridge apart and found nothing wrong with them. We have now reached the point where no hot water comes out at all at any time BUT, as usual, JUST AT THE KITCHEN SINK FAUCET. My son turned the under-sink shutoff valve to off, disconnected the hot water line, and turned the hot water back on. Not a drop came out.
I suddenly remembered a problem I had with a house I rent out: The tenant called; there's something wrong with the water heater. She gets in the shower, it's fine, and suddenly there's no hot water, just cold. Her husband takes a shower next -- same thing.
A plumber meets me at the house with a new water heater. I see that the tenant has paid someone to install a faucet handle on the old water heater. My plumber takes the old one out and says this is what caused the problem: when the faucet was installed, the piece of metal from the install fell in, and when the hot water was turned on and the water flowed out into the pipe, the piece of metal flowed up with it and shut off the flow.
So, I called the plumber who did the repipe and told him he apparently left something in the line when repiping and asked him to come out and fix his work. He says it is not the repiping; if it were, we'd have problems with the dishwasher and the other sinks. (The dishwasher hot water tubing comes out of the wall about 8 inches below.) It's the angle stop, and for $150 he will come and install a new one! I cannot imagine how a ball valve could suddenly shut off. At this point, however, the obstruction could well be lodged in or near the angle stop because we now NEVER get hot water in that sink.
Has anyone experienced -- or even heard of -- this problem? Solution suggestions? And should the repipe plumber be held responsible for checking this out/repairing at no charge? Thanks!!
In case you want a diagram of the repiping, here it is: Hot water heater is in garage against common wall to kitchen. Kitchen sink is on opposite side of room against common wall to dining room. Copper pipe was looped through ceiling space from garage across kitchen and down through the kitchen/dining room wall to the back behind sink plumbing. I did not see how this was hooked up to inside pipes.
