Hot Water smells
bewing
Arkansas
Hello, I recently started having a smell occur anytime running the hot water. I understand that this could be due to the anode in the hot water heater causeing a reaction with SRB's in the water. However my question is about how the bacteria could be in the water? The well is a fairly new well, I have been in the house for a little over 2 months and it was a new construction. I also I have a filtration system on the well, because I had an iron content of 1 ppm and also a presence of total coliform. The system consist of in order:
Chlorine Injection system
120 gal retention tank
Catalox Iron filter
Backwashing Carbon Filter
My well pump can produce 10 gpm.
Now finally for my quesiton. If my chlorination system is working correctly (I check it periodically and it maintains a Free chlorine of 1ppm) how would it be possible for bacteria to be getting through to cause the smelly water in the hot water heater? Thanks for any advice.
Barret
doug george
idaho
This doesn't really answer your questions but a similar situation is very common in RV's. Some brands use aluminum tank , other lined steel tank. Both seem to have problem of smelly water at times, smells like rotten eggs or sulfur. It only seems to occur when the water is hot only , RV water heaters spend much of the time cold. If there is a worn anode inside it really stinks and may contribute to the problem. Our solution which seems to work for awhile is to flush tank and superchlorinate. Many tanks have a lot of calcium buildup which I'm sure adds to the problem.
