Hot Water Smells
Discussion in 'Water Softener Forum, Questions and Answers' started by bewing, Aug 18, 2011.
  1. bewing
    bewing New Member
    Aug 7, 2010
    Arkansas
    Hello, I recently started having a smell occur anytime running the hot water. I understand that this could be due to the anode in the hot water heater causeing a reaction with SRB's in the water. However my question is about how the bacteria could be in the water? The well is a fairly new well, I have been in the house for a little over 2 months and it was a new construction. I also I have a filtration system on the well, because I had an iron content of 1 ppm and also a presence of total coliform. The system consist of in order:
    Chlorine Injection system
    120 gal retention tank
    Catalox Iron filter
    Backwashing Carbon Filter
    My well pump can produce 10 gpm.
    Now finally for my quesiton. If my chlorination system is working correctly (I check it periodically and it maintains a Free chlorine of 1ppm) how would it be possible for bacteria to be getting through to cause the smelly water in the hot water heater? Thanks for any advice.
    Barret
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You can recontaminate the system with your hands just touching the filter elements. In some cases people will change out the anode or remove it and risk shortening the heater's lifespan. Others will raise the temperature. I opted to raise the temperature and never get any smell on the hot water. I do sometimes get it on the cold side and need to run some bleach through the plastic cold supply lines.
  4. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Before putting all the equipment in service, did you allow chlorine to flow through all the piping (hot & cold)? If not, you could put all the units on bypass and run water throughout the piping system allowing chlorine to disinfect the pipes and heater.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I've had that problem with several water heaters, always solved with a new aluminum/zinc anode rod. My water is now being heated via a solar panel, and typically is over 160°F when the sun is shining, so that may help. A temporary solution is to pour a quart or so of hydrogen peroxide into the water heater.
    FWIW, a neighbor has a Kinetico system, with hot-water smells. The Kinetico guys talked him into a Kinetico add-on filter for iron removal, and he still has the smells.
Similar Threads: Water Smells
Water Softener Forum, Questions and Answers RO water smells like fish May 13, 2011
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Monday at 7:41 AM
Water Softener Forum, Questions and Answers Opinions on treating well water Feb 12, 2017
Water Softener Forum, Questions and Answers Resin in Water Feb 12, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
