Hot Water Singing...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thinkly, Oct 15, 2009.
  1. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    We moved into our new home a few months ago. Shortly after moving in i noticed that whenever any of the showers (3 of them) are turned on there is a singing noise throughout the house.
    I wouldn't describe it as a whistle because it isn't that high pitched, but rather like a high pitched hum or "singing." It's not REAL loud but is audible everywhere if you listen for it.
    What can this be?
  2. jadnashua
    Do you have the same model showerhead in each one? Maybe the restrictor is singing...
  4. Cass
    Cass Plumber
    Nov 12, 2005
    It may be a bad pressure reducing valve if you have one...I have also seen the check valve that some meters have do it...
  5. hj
    hum
    It may be the "heat traps" in the water heater inlet or outlet lines. Bad water softeners and defective pressure reducing valves can also cause the noise.
  6. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    I've seen this exact thing recently, althought intermittently. The pressure compensators of some designs are more sensitive to this. It might be worth experimenting with another showerhead.
    Is it only doing it when the shower runs, not faucets?
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    What key is it in? B flat works for me :D
  8. Cass
    Cass Plumber
    Nov 12, 2005
    F sharp....
  9. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    Just happens with the showers. Oddly enough, we replaced both two of the three shower heads after moving in for aesthetic reasons. Still it sings. This is a fairly new house (only 8 yrs old), and will have to do more digging to find the answer.
    No other hot water sources cause this, so has to have something to do with showers, i.e. restriction of water flow.
  10. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    pull the water saver disc out of the shower head.
  11. jadnashua
    And run out of hot water in a few minutes...
    Are these tub/showers? The divertor in the tub spout can often make some nasty noises. Do they sing when filling the tub as well? Or only when diverted to the shower?
  12. Cass
    Cass Plumber
    Nov 12, 2005
    Pulling the disk will cause you to run out of HW sooner but will help you figure out if the disk is the source of the noise...
  13. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I have no water savers in any of my faucets and I don't run out of hot water. Then again I have a 60 gallon indirect piped to a Buderus 125
  14. Runs with bison
    Aug 23, 2009
    Midwest
    And as a result you likely also spend twice as much on hot water (plus water and sewer if it is not a well) as the normal customer. Not very good advice other than as a troubleshooting aid.
Similar Threads: Water Singing
Plumbing Forum, Professional & DIY Advice "Singing/Whiring" Water Pipes Aug 6, 2005
Plumbing Forum, Professional & DIY Advice Tap/clunk sound from water line (not water hammer) Yesterday at 7:30 PM
Plumbing Forum, Professional & DIY Advice Installing a whole house water filter by myself? (not a pro) Yesterday at 11:31 AM
Plumbing Forum, Professional & DIY Advice Silly question regarding toilet water supply line -- what size? Yesterday at 5:51 AM
Plumbing Forum, Professional & DIY Advice New water heater/PEX Sunday at 12:27 PM
