Hot water running out too quickly
Discussion in 'Water Heater Forum, Tanks' started by jhqpzjg, Jul 29, 2011.
  1. jhqpzjg
    jhqpzjg New Member
    Mar 11, 2011
    Boulder, CO
    I have a Rheem mod# 21V40-7 gas fired 40 gallon water heater. The hot water seems to run out too quickly for the size of the heater, which is particularly noticeable in the showers. I find myself constantly adjusting the temp in the shower toward hot while I'm in there in order to keep it from going luke warm. I noticed this problem first myself, and now have the same complaint from tenants now living there, without prompting them.
    I first checked for anti-scald devices in the shower valves, which I removed for troubleshooting. I also raised the temp on the hot water heater itself to just below the max. Neither step seemed to help the problem significantly.
    Any suggestions on cause or further troubleshooting would be greatly appreciated.
    Thanks,
    Jason
  2. jadnashua
    A 40-gallon tank can supply maybe 30-gallons before it starts to cool off (when working properly). That's maybe 12-minutes or a little more if your showerhead is the 2.5-gallon max type (depending on how much cold you need to add).
    If the thing was installed wrong, you could start to cool things off very quickly (i.e., the cold going into the hot port rather than the cold). Or, if the dip tube is either defective or missing, the thing will not be directing the cold water to the bottom of the tank, and it will mix with the hot and cool things off quickly.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You didn't say how old the tank is. If it is a few years old, there is a good chance that the dip tube has failed inside the tank. It is under the inlet pipe on the tank and forces the cold incoming water to the bottom. If the tank is in otherwise good shape, the dip tube can be replaced.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm late getting into this, but I will reenforce the previous suggestions on the dip tube although you could be just trying to use too much hot water too fast. The dip tube is easy to check, it hangs under the cold water inlet. If it is broken off, it's quick, easy, and cheap to fix. If that's not it, you aren't out too much time and no expense in checking it, so that's what I'd do first.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Or you could just fix the problem by changing the moen cartridges in any single handle faucets you have in the house
    when the cartridges get old and worn they allow cold water bleed over though the valve causing your problem
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I'd still check the dip tube before rushing out and buying cartridges or doing expending any money. Sure, it could be something else, but check the easy things first.
Similar Threads: water running
Water Heater Forum, Tanks Running out of Hot Water Jan 24, 2017
Water Heater Forum, Tanks Exhaust smell coming from hot water heater when it's not running Dec 19, 2016
Water Heater Forum, Tanks GE Hybrid water heater, Tips to get it running again? Jul 14, 2012
Water Heater Forum, Tanks AO Smith FPS 50 Powervent Water Heater: Burner won't stay lit, blower keeps running Nov 26, 2011
Water Heater Forum, Tanks Running out of hot water... Please Help! Feb 4, 2011
