jefferson17
We're considering a hot water recirculator but have some concerns if one would really be right for us, and if so, really which one. We have 4 stories of living space plus a basement below. The top 2 levels are each 1 BR apts. The water heater is in the basement, close to the risers.
I like the idea of the Watts (Grundfos) model. The price is ok at under $200. BUT ... from what I've read their "comfort valve" that is installed at the furthest point is designed with failure in mind (plastic inside the metal), and would likely need to be replaced every 1-2 years - about $50.
For us that means it would be installed in our 4th floor apt, under a tenant's sink. We really do NOT want a Leak Risk up there. That would be very bad for us. Whatever we might consider must be strong and worry-free but also cost-effective. $200 is fine. $400-500 isn't.
Right now most showers are within 50' of the current electric water heater. One shower might be more like 75' away. We'll be changing to an indirect that will be a further 50' away, connected via PEX. The 2 upstairs showers (3rd and 4th floor) are on old uninsulated copper). So if we're going to do this, it needs to be on a timer, or we'll lose a lot of heat radiating out of the older copper pipes upstairs.
One other option, is to only have this type of thing circulating between the current water heater and where the new one will be - to avoid any additional times from what people are used to today (probably would add about 30 sec with an extra 50' of 3/4 pex once water heater is moved). We've got really good pressure here so that's not a concern - just volume/time). I think that I could readily plumb in a dedicated loop in the basement, and perhaps some kind of mixing valve, to allow convection to automatically do this, but I'm not sure which type of mixing valve would "do the trick".
Thanks for any advice and recommendations!
Jeff
Jeff
