Hot Water Recirculation
Discussion in 'Remodel Forum & Blog' started by bross123, Dec 19, 2004.
  1. bross123
    bross123 New Member
    Dec 19, 2004
    Hi,
    I need some advice on:
    1. Pump size and a good manufacturer/model
    2. Return pipe size and type of pipe (will pvc do OK?)
    3. Is pipe insulation required
    This is for a residential hot water recirculation system which has copper pipes.
    I have 3 bathrooms, the farthest is about 70 feet from the Hot Water heater. I would like to run a recirculation system to save water and to get the hot water faster.
    Any help/advice would be greatly appreciated.
  2. hj
    hot water
    1. almost any pump will work.
    2. ANYTHING but PVC. It will get soft and burst when it gets hot.
    3. insulatiing the lines will help reduce your power bills and add to the life of the water heater.
  4. bross123
    bross123 New Member
    Dec 19, 2004
    hj,
    Thanks for the info on the PVC pipe. What size pipe and pump do you think I should install?
  5. jadnashua
    Your return line should probablly be the same size as the supply line. On the pump, make sure you get a bronze one (costs a lot more than the steel/cast iron), as it is required for potable water applications. My guess is that a TACO 007 would be sufficient. YOu could check out tacohvac.com web site and see what they use in their kit called D'Mand, then make your own choice. Note, I'm not a pro...
  6. hj
    hot water
    A stainless steel case pump will probably be cheaper than a brass one, unless you can find one of the small brass ones. The pump size is immaterial since you just want to keep water moving and a larger pump could create a high velocity which could cause pipe erosion. All you need is a 1/2" return line, but be sure to install a check valve after the pump before you connect back to the water heater.
  7. jadnashua
    Taco makes a circulator with a built-in check valve (it's relatively new). One less thing to install. Not sure if it is available in brass or stainless, though. Check their website tacohvac.com
  8. hj
    check valve
    Check valves eventually fail, you do not want to have to replace the entire pump when it happens. Install a regular pump and a separate check valve.
Similar Threads: Water Recirculation
Remodel Forum & Blog recirculation of hot water Jan 22, 2011
Remodel Forum & Blog Water Main line Dec 7, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Replacement water service questions: Mar 30, 2015
Remodel Forum & Blog Water supply question Oct 30, 2014
