hot water recirc loop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by shineer, Sep 29, 2005.
  1. shineer
    shineer New Member
    Sep 29, 2005
    installed a gravity hot water recirc loop and now it seems my hot water supply runs out much faster than it used to. I have the pipe insulated, it is 3/4 inch all the way back to heater. do I need to install a check valve, or what? The hot water comes almost instant but runs out too quick. can anyone help? Thank you.
  2. hj
    pipe
    Without a check valve at the heater, the cold water in the bottom of the tank will backflow and give you cold or cool water at the faucet.
  4. shineer
    shineer New Member
    Sep 29, 2005
    installed check valve at heater, everything ok now, thanks.
Similar Threads: water recirc
Plumbing Forum, Professional & DIY Advice Hot Water Recirc. w/ dedicated return Thursday at 10:27 AM
Plumbing Forum, Professional & DIY Advice Grundfos Timer Driven Hot Water Recirculation Pump - Name the Parts? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Hot Water Backfeeding - Issue with Recirculating Pump and Mixing Valve Jul 7, 2016
Plumbing Forum, Professional & DIY Advice Hot water comes quickly but recirculating pump is off? Jun 15, 2016
Plumbing Forum, Professional & DIY Advice Recommendation for small expansion tank for potable water recirculation loop Jan 12, 2016
